5 Red Shift cams similar to Jackhammer 570 ?
Last Post: Clevspeed
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
Last Post: Seek4aws
0 Year electronic diagnostics started
0 72 heads, do these look normal?
0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
0 $700 Ironhead ? Good value? depends who you ask
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
Old 14th August 2019
porch_hornet porch_hornet is offline
porch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of lightporch_hornet is a glorious beacon of light
Default Got my 77 running. How does it sound?
Please plug in your headphones and give a good listen. Post your comments.
https://youtu.be/DYNvbgenddk
Sent from my Pixel 2 XL using Tapatalk
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Sounds good! Ice that knee!!
stalkie's Avatar
stalkie stalkie is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumph T120,TR6+3 BSA's
Other Motorcycle Year: 1970
stalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond repute
Sounds like an Ironhead.
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: XL1200CX Roadster
Sportster/Buell Year #2: 2017
b0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond repute
idling too fast!
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
dont slow idle your IH.
spacecoast spacecoast is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant future
Agreed.
Skwerly's Avatar
Skwerly Skwerly is offline
Sportster/Buell Model: Unsure
Sportster/Buell Year: 1982
Skwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud of
yep, sounds just right for that IH. lowering the idle will starve it for oil.
Sounds like it should be ridden. Giddy-up!
+1 on the no-slow idle. Potatoes are for Big Twins...
Hazmat Life
xena's Avatar
xena xena is offline
Assistant Administrator
Sounds wonderful!
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 15th August 2019
randy3934's Avatar
contrary to popular belief, big twins "shovelheads" will smear pistons on cylinder walls if slow idled too.
