0 AGM battery for 76' XLH
Last Post: JonesL
0 S&S Super E Carb
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: Nitro57xl
0 so it's officially ended
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: class of 82
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
misfire
Old 17th August 2019
staniel's Avatar
staniel staniel is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: XL1200CX
Sportster/Buell Year #2: 2019
staniel is an unknown quantity at this point
Question What can cause the engine to suddenly misfire?
I put about 40 miles on my '71 XLCH yesterday for my first real ride with it. It was running really well - it was smooth and shifted good and I didn't have any issues at first minus a few pops here and there when I let off the gas a little bit.
But when I was about 3 miles from home it started to misfire like crazy making the ride incredibly choppy and made it difficult to accelerate. I could get into 2nd gear like this but I didn't want to push it to much so I took it slow the rest of the way home. At one point I just pulled over and let it idle for a bit to see if it would idle okay and it did. I think it only misfired under load.
The problem improved slightly as I kept getting closer to home.
What would cause it to misfire like that after riding smoothly for so many miles?
I checked the spark plug cables and they were connected well, I checked compression for the hell of it - was at 140 for both. Could it be a sticky distributor? Crud in the gas tank (it's pretty clean but not spotless)? I'm running 93 octane so I don't think that's the problem.
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
check battery cables
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Ignition settings may have shifted also. If points. Easy enough to check. If setting OK on points. Check for broken springs on weights, broken roll pin on back of weight holder post cludge.
I'd go the auto parts store and buy me a spare condensor for it also. https://www.amazon.com/Standard-Moto.../dp/B000WJCP5C
Just showing what brand I try and find at the auto parts store. Loose cables like suggested above though is good first check. Loose grounds, etc ......
Edit: forgot to mention since most new members here leave out info when asking something.
If the tank hasn't been cleaned. It will cause this also when running on dregs of fuel on bottom of tank.
Traveled to
Might have the carb set too rich and it's fouling plugs.
If the plugs are black you need to correctly set the idle mix HOT
Old 18th August 2019
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
40 miles. Did you start out with a full tank of fuel ?
I can go about 100 miles on mine before I have to switch to reserve. Not really all that far. I get about 14 miles on reserve and then I walk.
Assuming it's not out of gas, does the problem go away once the engine is cool ?
If not, that rules out heat related issues.
doodah man's Avatar
When something like this rears it’s head on my bike I immediately suspect electrical/ignition.
Whitewalls's Avatar
Sportster/Buell Year: 1971
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
+1
When I first got my Ironhead going I had the same issue. The points were brand new but cheap and poor quality. They would not hold the correct .018 gap and a pin hole burned through the center of the tips within 300 miles. I installed good quality points and they now have over 3000 miles with routine cleaning and maintenance.
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
Chk & make sure your kill switch wire isn't chaffed anywhere.I had one that was right where it came out of the frame.
Murphy's Law :vvet:
