0 Down on oil
Last Post: Billy1200
Last Post: seajay
0 Cancelling auto renew
0 Koso hd-01-04 2014+
Last Post: groovemeisterus
0 CV carb running way rich!
Last Post: Mission1
Last Post: Tipofthelake
0 Front Master Cyl rebuild question
Last Post: canoli
5 Harley T-Shirts
0 I was at the gym yesterday
0 Ok, talk slowly and use small words LED tail lights
0 Swingarm Bearing Preload Question
Last Post: rocketnorton
0 Ignition advice
0 900cc Cylinders
Last Post: Staffords
0 What’s your fuel injected 1275 idle speed?
0 Easy Brackets on 93 Sporty
0 Coil Resistance Question
0 Rear sets?
Last Post: bordens
0 Rear wheel alignment
Last Post: v3ko123
0 Sprortster Softail 1200 with Edelbrock NOS
Last Post: Randy_rots
Old 15th February 2005
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Nutsy, tell your service guy to reference Service Bulletin M-1162. If you have a 2004 or 2005 Sporty you should end up with Program # 32622-04. Good luck!
Old 16th February 2005
nutsy nutsy is offline
Sportster/Buell Model #2: 1200 custom
nutsy has disabled reputation
i will luxblue,thanks
GOTWA's Avatar
GOTWA GOTWA is offline
GOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enough
I just bought a stock 05 XL. In the next few days I'll be taking it into the dealer to have the performance upgrades done (pipes, a/c, jets). Is this something I should ask them about when I go in or is this unique to a SE add on?
rider1951's Avatar
rider1951 rider1951 is offline
Other Motorcycle Model: Suzuki DL1000
Other Motorcycle Year: 2002
rider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to behold
Is your bike a 2005? If so look under the seat and see what part number is on the ICM, if it ends with an A you are already in business. With that said it never heards to ask the dealer.
Impact Blue 1200 Custom, Gronk's mod stock exhaust, Ram-Flo 400, 45 slow, N65 needle, 175 main, HD detachable windshield and rear rack/ back rest, lay-down license plate, Mustang wide vintage, Progressive 13 1/2" 418s and Progressive fork springs w/ Belray oil, Superbrace,
Old 25th February 2005
mroy05's Avatar
mroy05 mroy05 is offline
Sportster/Buell Year: 04
Other Motorcycle Model: Dyna Glide Custom
Other Motorcycle Year: 06
mroy05 is on a distinguished roadmroy05 is on a distinguished road
What does ICM stand for? how does it affect the speedo and hiccups?
Thanks for bearing with me.
LuxBlue's Avatar
ICM = Ignition Control Module. The "brain" so to speak. It's the black box right under the seat. It holds the program for the ignition timing and fires the coil, receives info from the MAP senser and the crank sensor. etc. It also sends the pulses to the speedometer/odometer. H-D issued a service bulletin M-1162 that adjusts the pulses to the speedometer/odometer and adjusts the curve to aid in better cold starting, hiccups, etc. No parts needed, just a re flash of the ICM's memory and you're good to go. Current program is #32622-04A. Hope this helps.
mroy05's Avatar
Talking
Thanks.
I asked the dealer today to look up my VIN for any service bulletins and the only one they had was concerning the fuel supply valve.
I'll be able to be more specific and hopefully they will be able to find it.
rider1951's Avatar
Originally Posted by mroy05
Thanks.
Take the seat off and see what number is on the ICM, if it ends with 04A you already have the current flash. If your bike is an 05 and was produced late in 04 then chances are good you don't need anything done. Also another way to find out is check your odo against the mileage signs along the highway if your mileage over 20 miles matches your are okay.
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
I had to do a little convincing to get the dealer to do it to my bike...they didn't think it was for the XL's, just the Big Twins. The tech that had been wokring on my bike said it wouldn't hurt hurt anything, but probably wouldn't help much either - he said my bike idled better than most as it was. With all of the other changes made at the same time, it will be hard to tell a difference when I get to ride it again in a few months. The only thing I'll be able to look for is carb farts.
Old 28th February 2005
JaggedEdge's Avatar
JaggedEdge JaggedEdge is offline
JaggedEdge is an unknown quantity at this point
The bulletin says the bike should be a 2004 and a 2005 manufactured before
mid September '04, to get the update.
JE
Similar Threads
Review for Mustang seat #76440 klamen Product Reviews 22 24th July 2007 19:02
2005 30th Anniversary Honda Goldwing Review wagoneer12 Product Reviews 16 31st May 2005 08:54
HD gloves review engine Product Reviews 2 8th April 2005 03:22
ICM Reflash Idle Speed Increase? DM-SC Rubber Mount Sportster Motorcycle Talk (2004-2006) 3 15th March 2005 05:32
