Last Post: painthuffer
0 so it's officially ended
Last Post: Nicktater
0 Xl???
0 old parts
0 Sportster drag bike
Last Post: Zip1
Last Post: robbie202
Last Post: ericfreeman
Last Post: FrankGS
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Samedward
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
Old 19th July 2006
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Originally Posted by lagerdrinker
at 90 mph you can be in 4th or 5th gear. any difference in gears selection? neck bearings too tight?
you say this happens on ramps. are there small road seperations? reason im asking is while my bike doesnt wobble high speed straight line, if i go over those road seperations while a little bit leaning my handle bars will momentarilry wobble violently. i think they are just little underforked for how i ride.
Neck too tight?!?!?!?! Why do you say that? Wouldn't tighter help eliminate it?
The Older bikes used to have that friction damper on the neck that you could tighten donw to hardly be able to turn. Gear selection doesn't seem to matter, nor does it seem to be a big difference whether accelerating or coasting. I'm like you though....I always thought it was tires that started it when heeled over....but today it started on smooth concrete on interstate in a sweeper you could handle at triple digits. I was pulling in 5th at about 90 and it started the old "I'm gonna throw your butt off punk" shake.
Stuff: YES
Old 19th July 2006
TJB50's Avatar
TJB50 TJB50 is offline
Sportster/Buell Model: 1200 XLR
Sportster/Buell Year: 06
TJB50 is an unknown quantity at this point
Default H/D oil in forks!
What's interesting is I didn't have this problem, or didn't notice it until I put 412 shocks on it with heavy duty fork oil.
Old 19th July 2006
xena's Avatar
xena xena is offline
Assistant Administrator
I had a major wobble about a year and a half ago. I
retorqued the riser bolts (the ones that hold the risers to trees)
and my front axle bolt to spec and have not had the wobble since.
I know you checked everything but just making note, this was my fix.
Hope you find the prob and fix it before you tear all your hair out.
edit: The death wobble on my bike occured at 65 mph in a straight line but
I know what I did fixed it because afterwards I got her to 105 mph with no issues...
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 19th July 2006
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
not sure, just a wild guess. maybe if too tight it would restrict smooth movement
maybe like xena mentions, riserbolts. howabout bushing upgrade to uerothane?
bearings that are too tight can chip race and leave a pocket for balls to go in and out
Old 19th July 2006
No Posts
tire pressure? have you experimented with that? im figuring you have but just throwing out anything that comes to mind.
Old 19th July 2006
No Posts
wheel balance. they put on tape weights right? probably on one side of rim. buy some tape weights, remove the ones the put and put new tape weights evenly on both sides of rim at same weight you took off.
Old 19th July 2006
alexcue's Avatar
alexcue alexcue is offline
Sportster/Buell Model #2: Ultra Classic
Other Motorcycle Model: Kawasaki 500R
Other Motorcycle Year: 2000
alexcue is an unknown quantity at this point
Mine gets a wobble on certain roads. The rain grooves that they put on some of the CA freeways, can be a pain in the rear at certain speeds. It's like the grooves on the tire fit perfectly and "catch" the rain grooves. This upsets the front and causes a wobble.
I've also noticed it when the front wheel lightens, on some up-hills and i catch a cross breeze. the front wheel and handlebards start to shimmy a bit. I've always thought it was the front shocks that caused this problem, since i haven't replaced them yet.
The few times i've gotten up to 90+ i don't like the way the front end starts to feel, so it might just be inherent to the Sporty as it really lightens up and doesn't feel like it's contacting the road up front.
2005 1200R Sportster
Stage 1 w/ SE II and SE A/C
1200S Rear Shocks, HD Auxilllary Chrome Lights, Turn Signal Relocation, Adj, Hi-way Pegs, Kuryakyn ISO Grips w/Throttle Boss and ISO Pegs.
Old 19th July 2006
BWP 5p's Avatar
Good thought but they split them like you said. They really didn't take much weight either!
I'll start messing with pressures. They had 32 front and 36 rear in them.
I'll check all the fork bolts again too. Maybe I need BIG forks!
Old 19th July 2006
No Posts
im thinking the same on mine. like i mentioned a few posts back i get a violent wobble at high speeds over road seperations even with emulators, springs, heavier oil. it does leave me a bit uneasy
Old 19th July 2006
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
I've had bad tires do this on me.
Also I would check the free play on the wheel bearings.
