Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > NON-ENGLISH FORUMS > Suomeksi
Suomeksi Suomenkieliset sivut
0 WTF Happened
Last Post: smilinbrad
Last Post: bklyngeezer
0 21 vs 22 vs 23 teeth sprocket
Last Post: Akdawg
0 tapped adjust
0 The salty debate thread.
0 $700 Ironhead ? Good value? depends who you ask
0 Kick starter resistance
Last Post: joes95bobber
0 Static timing
Last Post: ftwflh
0 05 carb rebuild no start
Last Post: randy3934
0 Starter solenoid short
Last Post: Yellowstone Kelly
6 ironhead turn signals
0 Smacked a deer last night
Last Post: Deimus
Last Post: BigMek
0 Handlebar risers
0 Spitfire motorcycle 2 into 1 Blaster
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
Old 6th February 2008
samppa's Avatar
samppa samppa is offline
Sportster/Buell Model: XLH883H'97
samppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of light
Originally Posted by NicNac View Post
Joku 2-1 putkikin vois tuohon passata hienosti...
Jep, joku supertrappin 2-1 tai pro pripe -tyylinen putki olis kyllä aika passeli. Mut rautiksen 2-1 -putket on aika harvinaisia, niitä ei kovin usein tule vastaan ja silloin kun tulee, hinta on melkoinen. Tietty jos sais jonkun vääntämään käyrät...
Kunnon morsettaja piikkaa molemmin käsin.
Harley Sam's Avatar
Harley Sam Harley Sam is offline
Harley Sam is an unknown quantity at this point
Joo eipä ole 2-1 putkia rautiksissa pahemmin näkynyt. En tiedä mikä 2-1 putkissa on mutta en itse pidä niistä kovinkaan paljon.
Jimmy Dix: It's called a vocabulary. You got one of those?
Joe Hallenbeck: Sorry, my subscription to JUGGS magazine ran out.
-The Last Boy Scout-
Old 7th February 2008
samppa's Avatar
Noo, makuasioista ei voi kiistellä. Mut mulla on muutenkin suunnitteilla sellainen kevyehkö cafe racer -lookki, nokkakuuppa ja alaskuuppi, siihen sopisi 2-1 -putkikin aika hyvin.
Tosin ensin olis saatava muut hommat tehtyä, sain eilen vihdoin vaihdettua nokat, viikonloppuna pitäis varmaan päivittää takajarru uudemman malliseen ja sit olis vielä kytkinremppakin...
Laitetaan nyt kevennykseksi se toinenkin poski.
Tarkimmat varmaan huomasivat paperin takahaarukan päällä... Eli huomasin pyörää käytellessä, että mullahan olikin öljytankki murtunut ja samasta kohtaa kuin edellinenkin, etummaisen akunkannakkeen juuresta. Sekin tuli sitten vaihdettua h-d:n päivitettyyn malliin, oli aika ikävä homma saada öljyletkut reititettyä, pitää joskus vielä siistiä (vaatii startin irrotuksen).
Harley Sam's Avatar
Hieno satula. Itse ajattelin vaihtaa johonkin saman tyyliseen. Pitäisi vaihtaa kun on liian ohut olis paksumpi vähän mukavampi pitemmille matkoille.
samppa's Avatar
Joo, toi on corbinin gunfighter... Osu silmään Saksan ebayssa ns. sopuhintaan ja oli melkein pakko ostaa. En ole vielä ajanut metriäkään mut kylmien tyyppien perusteella ajoasento menee keskitappien ja perustangon kanssa aika kohdilleen.
NicNac's Avatar
NicNac NicNac is offline
Sportster/Buell Model: 883/1470
NicNac has disabled reputation
Minkä verran evon putken kiinnitys sitten eroaa rautsikan omasta?Jos pienellä vaivalla sais muutettua rautsikkaan sopivaksi.
Sellaanen rosterinen supertrap sopiis kyllä siihen cafe racer teemaan.Paa se nokka koppa mutta unohda se scooppi
samppa's Avatar
Evossa on laippakiinnitys ja putki on kannenpäästä ulkohalkaisijaltaan luokkaa 45 mm, kun rautiksessa taas putki puristetaan klemmarilla kiinni kannessa töröttävään lähtöön ja putken ulkohalkaisija on n. 48mm. Kaipa toi jotenkin tehtävissa olisi, mut itse en kyllä osaa sanoa miten tuon voisi hoitaa. Ehkä helpointa olisi ostaa jotku halvat rautiksen drag pipet, leikata noista lähdöt ja hitsata evon lähtöjen tilalle.
Tässä näkyy noi rautiksen pakolähdöt:
Tässä menee nyt vielä vähän aikaa miettiessä tota lookkia, jos hommaan pikkukatteen, sen joutuu maalaamaan ja sit melkein pitäis maalauttaa mutkin pellit... Ehkä vielä ensi kesä tässä kuosissa.
Old 8th February 2008
NicNac's Avatar
Kyllähän tuon luulis onnistuvan kun sorvaa sellaaset kohtuu tiukat sovitteet johon kunnonllinen klemmari sitten kylkeen.Ne sitten hipsailee putkien päähän...
Joo no komeehan se nuonkin on...ja sun pyörä.Kunhan kommentoin
samppa's Avatar
Kuten sanottu, kyllä mäkin sitä 2-1 -putkea olen miettinyt mut kun olen tällanen autotalliharrastaja, niin ei ole sorveja eikä hitsejä käytössä...
Noi nykyputket tuli hommattua jälleen kerran ebaystä, kun huomasin et siellä tehtaan NOS viriputket kaupan. Ja kuten arvata saattaa, niin sopuhintaan nekin, en ihan kympilä diggaa noista "baloney cuteista", joko supertrapp 2-1 tai xr-putket olis kova sana.
Kevennykseksi tunnelmakuva rautapääukon elämästä:
Old 9th February 2008
samppa's Avatar
Kun kerran kuvia on alettu laittamaan, nin tässä on sit '85 rautiksen jakopää Andrewsin PB+-nokilla... Jaan vapaasti tota pyykkipoikapatenttia nostajien ylöspitoon (tai kaljat saa tarjota päärallissa ).
Ja kommenttia pitää tullakin, niistä saa hyvästi aihetta miettiä asioita uudelleen. Ton mun springerin kanssa meni 5 vuotta ennekuin sain sen siihen malliin etten enää mieti mitä pitäis tehdä (paitsi nokka vaihtaa EV46:sta EV38:iin):
Nyt olen aika tyytyväinen, mut tästä saksan irman pyörästä lähdettiin mietiin et mitäs tekis:
