Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Service > Sportster Motorcycle Service Bulletins
Sportster Motorcycle Service Bulletins Here is where you can post Official HD Service Bulletins that concern Sportster motorcycles or motorcycles.
2 My 1275 Hammer Conversion..
0 su carb question
Last Post: fafcpa
Last Post: DitchTBHSMM
0 New to the Chopper Lyfe
Last Post: TUCCI
Last Post: brixtonanima
0 Too HOT to ride?
Last Post: Billy1200
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
Old 20th August 2005
883 custom 883 custom is offline
883 custom has disabled reputation
Aerosport, I have the twin tec ignition on my 05 883 as well. My speedometer was off, but it was also registering all over the place. I ended up sending it back to them . They said it needed the software updated, why I dont know it was brand new. Anyway they updated it, then they calibrated it for my bike free of charge. It now registers right and no more bouncing around. As far as settings, started with 5-5, then went 5-7 and thats where it is now. Runs a little stonger on 5-7 but I have not experimented with other settings. As far as the speedometer diagnostics mine just says diag when checking it. The check engine light doesnt go out until it is started where as before it would go out about 3 sec. after the ign. was turned on.
Old 21st August 2005
Rino Rino is offline
Rino is an unknown quantity at this point
I own one of the first production 1200R's and noticed that the speedo was reading a bit low; the dealer did never anything about it, but through this forum I found the HD notification about the need for a reflash. This was duly installed by dealer.
I have to say that the bike ran fine before the reflash (never carb farts); and I do not notice any change after the reflash.
Old 24th August 2005
hero's Avatar
hero hero is offline
Sportster/Buell Model: ex 1200 C rider
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 2010
hero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the rough
Originally Posted by CBAS5
I did notice the pipes have more bark to them. They just sound louder when I roll on the throttle. I'm not sure if this is related to the reflash or not because I noticed the mechanic made adjustments to my enricher, brake lever, throttle, etc.
I also had mine done recently & noticed the change in exhaust note. Not sure if I like it- it seems louder out the rear, but more raspier & not as deep as it used to be. Maybe it's just me.
Stef.
Old 3rd September 2005
John L John L is offline
John L has disabled reputation
Just got my 2005 / 1220 Custom back form the dealer. Was purchased with SE Pipes, Air Cleaner and Carb Jet was changed.After many "Can't find a problem" visits, the service manager stated after another test ride, he had the same experience with carb poping. Dealer claimed to change the Crankshaft Possition Sensor and installed new factory carb. Run's good now and mileage when form 31 mpg to 53 mpg. I think it may be running to lean? I did not check the ECM/ICM code before the service, but now it is #32889-04A. Not a match for service Bulletin M-1162? Anyone know anything about this code?
Old 13th September 2005
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
Hey john if your bike running good now after the the new carb i would'nt worry about it. And those reflash numbers i think are updated sometimes. So if its running good don't worry about it. Why do you think its lean? I guess the dealer rejetted the new carb? And again john those reflashs just change the timing a little so no matter what number is if its running good forget about it.
dakota_dj's Avatar
dakota_dj dakota_dj is offline
dakota_dj is on a distinguished roaddakota_dj is on a distinguished road
I had the ECM reflashed yesterday on my 05 1200XL C. The original Calibration Number was 32819-04A. The Vehicle Recalibration Report they gave me shows the new Calibration Number of 32819-04B. The bike runs like a scalded dog now. I have drag pipe slipon pipes (no baffles), rejetted slow jet to #45, turned Idle Mixture screw out 2 1/2 turns and installed a Hypercharger.
At the bottom of the Vehicle Recalibration Report it states:
Description of New Calibration
Revised Stock Calibration to Update Strategy Level. This Calibration retrofits for
this model and is comparable or superior to the O.E. Calibration from an emissions
standpoint.
