0 Good 2 into 2 exhaust?
Last Post: FearTheBeard
5 Favourite grips?
0 What riding gear do you have/wear in good and/or poor weather?
Last Post: TheDinglepuss
0 Another ironhead roadracer
Last Post: Martysf
0 Topend problem
Last Post: dodgetrucken
0 1200s mid throttle stumble
0 Helmet poll
0 S&S pushrod adjustment
0 New problem with 1200s (Rev Limiter)
0 Sportster tachometer wiring question
Last Post: clif02
Last Post: Martysf
0 1986 1100 butterfly carb on going problems
Last Post: Flam
Last Post: Bryan1976
0 Paughco Tank 866XL1 – 2.9 Gallon Capacity
Last Post: heyshott 81
0 Dealer says, "Sportsters are just a Phase"
Last Post: lostNdallas
0 Air cleaner backing plate screw size?
0 Why I am leaving the forum!
Last Post: khav
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 New England 2018
0 09 Buell XB12 crank
irvingjr (70), 909XR (61), Ghost_FL (59), mark R (58), TWISTED (45), spade (43), Drivethis29 (38), dodgetrucken (33)
mikeLI_77's Avatar
Have you checked for an intake leak. The speratic idling could be due to that.
2002 XL1200C (originally)
Supertrapp supermeg exhaust 20 disks and open end cap, S&S roller rockers, Alto Carbonite clutch with Energy One 15% heavier spring plate, Daytona twin tech single fire ignition 1005s
Ricor intimnators, 13" Ricor IAS shocks, Brembo dual disk setup from a 2012 street glide with matching brembo street glide master cylinder,
States I Have rode through
Are you certain of the noise location? You listened with a stethoscope? Screwdriver? Funnel & hose? Lifters or Rockers? Something else?
Maybe a bad lifter that starts to malfunction as the oil thins during heat up?
Idle speed - Float level & valve seal? Petcock diaphragm? Vacuum hose? Map sensor?
What was the last thing you did to the bike before this started?
2 Relax
have you check the slide diaphragm?
if the oil viscosity is down, could affect lifters when hot and do not rule out a filter going south. remember "KISS" before the $hop.
GreyGuitar GreyGuitar is offline
GreyGuitar is an unknown quantity at this point
Thanks for the further replies.
Interesting turn of events this morning, it’s not necessarily related to temperature. I started it cold this morning after the bike sitting overnight and the noise was present immediately. I’ve checked for intake leaks, the manifold seals are fine, as is the slide diaphragm. Since reassembling, the bike runs smoother but the noise is still present.
Whilst I can’t say for certain the noise is the lifters, it’s coming from under the rocker covers and sounds very much like a louder, slightly harsher version of a typical HD lifter noise. It definitely sounds similar to a bike with very old/not enough oil.
The exhaust note, and not necessarily at the muffler, sounds louder and ever so slightly less deep.
In terms of what I’ve done to the bike prior, I hadn’t touched a thing for quite some time, the noise just started happening one morning.
I have had a lifter go bad.... just saying.
Old 6 Days Ago
Update on this, I think it may be down to a lack of oil circulating/oil pressure when warmed up.
Is there a way to check if oil is returning? I’ve got no gauges/indicator lights so wouldn’t have gotten an oil warning.
If indeed it is the oil, is the likely cause a problem with the pump or is there other things to check?
Old 6 Days Ago
mikeLI_77's Avatar
you can tell if the oil is returning to the oil tank by just taking off the oil cap and you can see the oil circulating in the tank.
Old 6 Days Ago
Yep - Which should be a frequent action since you eliminated the OIL warning light...
2 Relax
