0 Spark plugs
0 Greetings from Missouri!
0 Slash cut drag pipes without oxygen sensors wanted
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: brianbbs67
0 04 21" spoked wheel front brake upgrade kit
Last Post: Calcustom
0 Help with a Harley Davidson side bag
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 turning idle mixture screw no effect?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
0 Mid West Meet & Greet
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
2 Your daily tunes...
Last Post: RDHenley
0 DK customs suspension
Last Post: Bryan1976
0 Polished rotor/brake pad compatability
Last Post: RDHenley
0 '81 swingarm internals
Last Post: Scott
0 Shoulder Height Handlebars for 883 Custom?
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
  #71
Smerch's Avatar
Smerch Smerch is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: Heritage Softail
Smerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to behold
There's a big thread in the stickies about Ultima mapping-
http://xlforum.net/forums/showthread.php?t=1757704
Are you buying a cable to program your ignition when it shows up?
Mission1's Avatar
Mission1 Mission1 is offline
Sportster/Buell Year: 1974
Mission1 is an unknown quantity at this point
Cable came today!
Mark Cunningham 74' XLCH Iron head
Mission1's Avatar
I read that, but he didn't mention what kind of setup he was running which i thought would be important to mention for reference! He mentions that not all setups are the same as would be his but not touching on that we have no real reference to start with. I suppose specific to his setup using a Voes suggesting later 70's into the 80's evo. Mine being a 74 xlch kick start will use zero dead rev's. I did get a VOES in case it's needed but that requires drilling into my SS E manifold.
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Originally Posted by Mission1 View Post
... I did get a VOES in case it's needed but that requires drilling into my SS E manifold.
I drilled mine. The first part was to find the thickest part of the manifold to install which would also be a convenient location. I was going to use the marked spot on the back but decided against it...
Try to get one of these, a vented cap screw, a somewhat common automotive part...
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Mission1's Avatar
Did you find that the VOES was very beneficial and necessary?! I hope this one is the correct one if so! What size drill and tap?!
MC-V0S3
IronMick's Avatar
It needs only a tiny tiny hole in whatever part you insert. If you can get one of those vented screws from an auto supply that would be easiest. Just get the smallest one they have and drill and tap to fit the screw threads.
When you decide on the spot to use ensure that it will not interfere with the mounting arrangement
The engine performs better with the VOES. I was using Wiseco 10:1 pistons and had to work at eliminating the pinging. The VOES was a help. I just trust the overall performance was better. Hard to judge. All that f@cking racket from the engine
Mission1's Avatar
I’ll keep that in mind! Weisco is a few cities away from me in Ohio and I used their pistons for my VW project! If you e used the Ultima is there a stick map used to start with?!
IronMick's Avatar
I do not know the terminology "stick map". With the Ultima for a street bike, just install, set static timing and go.
Mission1's Avatar
Did I say Stick map?! Lol I meant Stock map settings!
Old 2 Days Ago
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
no programming needed
no VOES needed
no worry about dead revs
73- 1st kick bike, SU, runs like a top
81- starts first push of botton, S & S carb, a sweetheart of a bike
Got tired of the junk points components, and went to EI 3 years ago with the Ultima and have had zero problems or concerns on either bike
CHOPPERS MC S.E. MINN- Chopper for Life- "Old School" Steve Gappa on facebook
