0 Roadster Dampers in Nightster
0 what you think
Last Post: Hellbent_4
0 1955 KH motor on E-Bay
Last Post: night-train
0 Kayaba forks no springs? Help with missing parts
Last Post: Bturkey
5 Tire Pressure?
0 can you tell me why?
0 Wont shift from 1st to 2nd
Last Post: bmax13
0 Powervision autotune questions
Last Post: mastiffhound
0 Throttle Body loose
Last Post: MachU
0 A visit to the Norley workshop
Last Post: Merch131ho
Last Post: Oldmxdog61u
0 Power cones
0 Wheels
0 What's your opinion on LED light kits?
0 clutchless 2003
Last Post: lehel
0 Super E knock offs?
0 American Flat Track revised 2020 schedule released
0 Mid West Meet & Greet
Last Post: Bow only
0 Spark plug discrepancy
Last Post: Ted Town
0 floor boards for rear passenger?
Last Post: Joe_jeep
0 93 Sporty Key replacement
Last Post: Joe_jeep
Old 4 Days Ago
the rough finish improves fuel atomization the way i understand it.yosimura was improving atomization back in the 70's when he changed the shape of the needle in the mikunis.
Old 3 Days Ago
Sportster/Buell Year: 1969
RicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to behold
On your aluminum intake if you do anything to it check transition from carb to intake is same size, alignment to heads for good seal and airflow. Many have already alluded to finish inside manifold. If there are rough casting clean it up. Based on current data the ports with the best flow numbers are a modified D port with part polish part textured runner. FLow bench and $$$. How fast do you want to be?
