Last Post: mrmom9r
Last Post: hexnut
Last Post: Whitewalls
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: 1Scooter
Last Post: MkC
0 2004 ICM
Last Post: oldboy
0 Willi is back!!!!
Last Post: bplinson
0 Front brake hose
Last Post: flthd31
2 Your daily tunes...
Last Post: RDHenley
0 Exhaust pipes
Last Post: Joe_jeep
0 It's me - Kokopeli.
Last Post: Joe_jeep
Last Post: bill smith
0 Mid West Meet & Greet
Last Post: Bow only
0 Proper XLCH
Last Post: spamer80
Last Post: keithnh
Last Post: Bow only
0 Highway cruise speed
Last Post: xElvis
0 2006 Sporty Charging System Upgrade
Last Post: RDHenley
0 Problem on a trip
0 Chinee Ignition
Last Post: RDHenley
0 900cc Pistons
Last Post: davixlrtt
0 Top End Whirring Sound
Last Post: Jason's Sporty
Captain Johnny Captain Johnny is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Triumph Sprint 900
Other Motorcycle Year: 1998
Captain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to behold
Default S&S MGAL carb
Gonna run this on the 66 XLH 900.
Does anyone know what the float height should be? Is it measured from the scribe line on the gasket surface to the float when the bowl is upside down?
Also, having trouble finding info on that long tube looking intermediate jet that screws in from the top of the carb. Don't know which one to install, can't find a selection of different sizes to try. The one in this carb has a "4" stamped on the top.
Can anybody shed any light on this?
RKN's Avatar
RKN RKN is offline
Sportster/Buell Model: 883 (90")
Sportster/Buell Model #2: 5" stroker in progress
Other Motorcycle Model: 900 CH engine in H frame
Other Motorcycle Year: 196?
RKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to beholdRKN is a splendid one to behold
GAL instructioms https://web.archive.org/web/20110106...ns/51-1008.pdf
Thanks RKN. Put everything together and a couple kicks later she runs. Now comes the fine tuning. Cool looking carb coupled with a magneto, good stuff.
11B40 11B40 is offline
11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold11B40 is a splendid one to behold
The GAL is just a big Linkert DC. I bought one brand new in 76 or 77 added the manifold and put it on my 66 magneto Sportster. The bike had head work with XLR valves and PB cams. I took off a good running Tillotson. I took it out and started it and rode off. It had an awful flat spot whenever it came off idle. Believe it or not, I called George Smith owner of S&S that same afternoon. told him what was happening. He asked me to give him the number off of the carburetor. He put the phone down (he was at his house) was gone for a few minutes, he came back on and told me that on that carb, they had drilled an air bleed hole a little bit too far back. He then told me to take out the butterfly and file a small bit off the top front of the butterfly at an angle (in essence opening up the air bleed sooner). I thought sure....... thanked him and did what he described. That thing ran perfect, unbelievable....smoother than the Tillotson, way smoother....We did some testing at Fremont drag strip with these carbs. Ran with the Tillotson, took off that and put on the big GAL and it went 10 MPH faster. Even the gas mileage improved, a lot. I used it when I went to 77" and it ran wonderfully, started better too. The long tube on top is the emulsion tube I never changed it, ever. I would use mainjets (35 years ago???) 70 or 72 for the 55" motor and maybe a 74-76 for the big 77". At the drags with straight pipes I would go up one size. That is the only thing I ever did. I would advise to not screw around with it much. It is the best carb ever made as far as we were concerned. Used them at Bonneville on 77" and on Roberts Turbo shovel when it first started. The only problem I can recall was a float broke on record runs and even though we were not supposed to, I ran back and took a spare and changed it for the return run. The Guys running the show wandered off when we did it so they wouldn't see what we did . They knew us and how hard we had worked for that first 176 MPH record. These GALs were about $125 new and are worth $500 now, you are a smart lucky guy to have found one.
That's a great story! Thanks for telling that. I'm running an S&S Super B on my 69 CH that runs like you describe above. Starts easily, runs really smooth and gets good MPG.
Looking forward to getting this MGAL running like that.
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Model #2: IronHead XLH
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Hi lads...
Thought I'll show you mine...
Touch moded…
Mine's # 736, not far from yours...
Patrick
Flat Head Forever
can you give us the tour?looks real interesting.off the KHK?
Hi, Brucstoudt…
Yes, off the KHK... Main jet!!!
4.4mm, that's 175 thou... There also a Mikuni adjustable main jet next to it for finer tuning!!!
Drinks between 3/4 to one liter of methanol per mile... Thursty!!!
I'm just about to start another build around that engine, maybe Bonneville again next year if travel can be resumed...
That'll be a treat for my 70th birthday...
Patrick
glad to hear you still have that.supercharger and all.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I have an MGAl and a GBL for my 58 CH but haven't decided on which to use.
I am a procrastinator.
Partly because I haven't fully decide to run it on Methanol.
