0 Crank Seal Missing; Is My Engine Damaged?
Last Post: MkC
0 2004 ICM
Last Post: oldboy
0 Willi is back!!!!
Last Post: bplinson
0 Front brake hose
Last Post: flthd31
2 Your daily tunes...
Last Post: RDHenley
0 Exhaust pipes
Last Post: Joe_jeep
0 It's me - Kokopeli.
Last Post: Joe_jeep
Last Post: bill smith
0 Your trans/engine rebuild advice
Last Post: Bow only
0 Proper XLCH
Last Post: spamer80
0 chrome xlch bosch regulator cover
Last Post: 1968xlch900
Last Post: keithnh
0 Greetings from Asbury Park, NJ!
Last Post: Bow only
0 Highway cruise speed
Last Post: xElvis
Last Post: RDHenley
0 Problem on a trip
0 Chinee Ignition
Last Post: RDHenley
0 900cc Pistons
Last Post: davixlrtt
0 Top End Whirring Sound
Last Post: Jason's Sporty
0 Simplified Wiring and Bars
Last Post: wannabehero
Last Post: RDHenley
Closed Thread
Old 16th December 2016
Lightbulb Contributions from DR DICK
Originally Posted by GA_Ironhead View Post
I don't think anybody here expects Mick to do this by himself. With the Dr's 6300+ posts, expecting any single person to cull the collection is beyond the pale. Let's help him out, search for our fave topics and provide links!
Thank you, GA_Ironhead. DR DICK has posted here for almost 7 full years.
This thread is to contain only links to threads or posts originated by DR DICK, or to which he has made a major contribution. Links may be to the thread or to an individual post within a thread. Any member of XLForum may make suggestions.
This thread is locked so that only myself can edit it. To include an entry please send me a PM including the thread or post title and link. I will copy the title and link into this thread.
When more posts have accumulated I will organise this into sections such as Clutch, Transmission, Electrical, etc as indicated by the content of the submissions.
EDIT: OK, I started a few sections; will continue as more threads are submitted; suggestions always welcome by PM
Entire Bike
getting this 78 back to the way it should be.
http://xlforum.net/forums/showthread.php?t=1297584[
Engine
Procedure for adjusting/tightening your cylinders and heads
http://xlforum.net/forums/showthread...in+Plug&page=8
purpose of the transfer valve
http://xlforum.net/forums/showpost.p...8&postcount=40
why crankcase case drain plugs strip
http://xlforum.net/forums/showthread.php?t=1595420
cam cover bushing line reaming mystique
http://xlforum.net/forums/showpost.p...1&postcount=18
Intake/exhaust valve size
http://xlforum.net/forums/showpost.p...08&postcount=7
cam cover removal
http://xlforum.net/forums/showpost.p...9&postcount=44
a little cam overview
http://xlforum.net/forums/showpost.p...3&postcount=12
Clutch
Dry clutch hub identification and interchangeability
http://xlforum.net/forums/showthread.php?t=1605960
How to keep a,dry clutch dry
http://xlforum.net/forums/showthread.php?t=1690249
keeping the dry clutch derby cover sealed
http://xlforum.net/forums/showthread.php?t=1891483
clutch steels, why wet slips/drags and why dry dont
http://xlforum.net/forums/showpost.p...4&postcount=21
adjusting a dry clutch:
http://xlforum.net/forums/showpost.p...89&postcount=9
Early Sportster Dry Clutch Springs
http://xlforum.net/forums/showpost.php?p=5465045
Transmission
how to blueprint your shifter
http://xlforum.net/forums/showthread.php?t=1734747
1954-1972 Trans Corner Reinforcement
http://xlforum.net/forums/showpost.p...40&postcount=1
trans access door alignment
http://xlforum.net/forums/showthread.php?t=1392866
c-ratio gearboxes
http://xlforum.net/forums/showthread.php?t=984801
http://xlforum.net/forums/showthread.php?t=1271769
http://xlforum.net/forums/showthread.php?t=978417
http://xlforum.net/forums/showthread.php?t=1523130
http://xlforum.net/forums/showthread.php?t=1582406
Stroker Engines
84 cubic inch 900 motor teardown pics
http://xlforum.net/forums/showthread.php?t=1208660
info on stroker piston clearance ... and piston design
http://xlforum.net/forums/showpost.p...9&postcount=26
Magneto
Magneto spark plugs
http://xlforum.net/forums/showpost.p...5&postcount=42
http://xlforum.net/forums/showpost.p...3&postcount=83
http://xlforum.net/forums/showpost.p...5&postcount=33
Magneto points - materials of construction
http://xlforum.net/forums/showpost.p...6&postcount=17
mag clearancing pix for 1000cc vin boss (retrofit)
http://xlforum.net/forums/showpost.p...3&postcount=33
three fm condensers
http://xlforum.net/forums/showpost.p...1&postcount=50
three fm coils
http://xlforum.net/forums/showpost.p...7&postcount=51
Carb and Intake Manifold
Super B float needle
http://xlforum.net/forums/showpost.p...53&postcount=8
intake manifold leak plague
http://xlforum.net/forums/showthread.php?p=3203642
Intake Manifolds
http://xlforum.net/forums/showpost.p...98&postcount=6
Frame, Wheels
Ironhead taming the short frame
http://xlforum.net/forums/showthread.php?t=1620249
Kickstarting a Magneto Sportster
deaf dumb & charly go racing
http://xlforum.net/forums/showthread.php?t=1666561
why battery "eliminators" are a scam
(referring to accell battery eliminator capacitor)
http://xlforum.net/forums/showpost.p...2&postcount=13
Pictorial Guide for Identifying Heads
http://xlforum.net/forums/showpost.p...44&postcount=1
chopper geometry basics
http://xlforum.net/forums/showpost.p...6&postcount=38
Covered rear shock repair
http://xlforum.net/forums/s...4&postcount=45
Early oil separator
http://xlforum.net/forums/showpost.p...68&postcount=6
http://xlforum.net/forums/showpost.p...1&postcount=15
http://xlforum.net/forums/showpost.p...9&postcount=24
Humor/Nostalgia
http://xlforum.net/forums/showthread.php?t=1804192
Steps for assembling your ironhead
http://xlforum.net/forums/showthread...in+Plug&page=7
ironhead timing change from 45 degrees on 900 to 40 degrees on 1000
http://xlforum.net/forums/showthread...1547480&page=3
57 to 76 production oil pumps
http://xlforum.net/forums/showpost.p...&postcount=204
1952-on Handlebars
http://xlforum.net/forums/showpost.p...5&postcount=12
big inch guys pay attn.
http://xlforum.net/forums/showthread.php?t=2004210
the other side of amf
http://xlforum.net/forums/showthread.php?t=2004212
early crash bars
http://xlforum.net/forums/showthread.php?t=2004209
Ironhead rear hub thread
http://xlforum.net/forums/showthread.php?t=1525902
Closed Thread
