0 Spark plugs
0 Greetings from Missouri!
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: Calcustom
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
2 Your daily tunes...
Last Post: RDHenley
0 DK customs suspension
Last Post: Bryan1976
0 Polished rotor/brake pad compatability
Last Post: RDHenley
0 '81 swingarm internals
Last Post: Scott
0 Shoulder Height Handlebars for 883 Custom?
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
Old 5th July 2019
Dogoargento Dogoargento is offline
Sportster/Buell Model: XL Sportster
Sportster/Buell Year: 1957
Dogoargento is an unknown quantity at this point
Default I found a 57 drag chopper 20 years in storage, ridden 5hs
First post here and to stay for a long time. I owned many many bikes for the past 20 years but this is one of a kind, my second Harley, the first one was another chopper but EVO. I will try to learn from all of you and I will appreciate any advice you guys can give me to find out what is on this beast.
The PO is a 74 year old motorcycle builder from Brooklyn, he came done here, South Fl, 20 years ago after a back injury and was not able to ride any more. This was his bike and he kept it since 1981 when he bought it basically as project in a box. Titled 1957, first year XL #3232. He built it in the 80's and rode it. Then he put it apart at the end of the 90' and rebuilt it again to be the Super Bike, as he calls her. This are some of the things he did to her and some pictures. I will continue finding out more about it but I do not know a lot about Harley's and I am trying to learn everything I can since I will keep her as well as my Vmax for ever since this guy out so much that I fill honored that I found it and I gave this gentlemen my word I was not going to sell her.
Built for performance and drag race.
Dual points plugs, Frank's Voltage reg, S&S carb, Andrews big cams, custom distributor, high compression pistons .60 over, changed the joggs, high performance clutch, big bore 1000cc, has 5 in 5 stroke 76", stroke kits are 72" or 74", this is a custom stroke done 25 years ago and ridden only 5hs, kept in storage for the past 20 years, Put a bolt drive because it kept snapping the chains in the primary, too much power. He beefed up the transmission housing (cases) because of the stroke power. So he took it to a guy with a crank balancer HD machine to do the job in Brooklyn.
I am located in South Fl and I would really appreciate if you guys know any member in the area with good knowledge about Ironhead willing to help and share a couple of beers in the meantime or even a nice Argentinian steak BBQ.
Here is a link with pictures. I am not able to upload pics since I do not have enough posts or I will try to do it tomorrow from my computer. If you guys can upload pics from the link I would appreciate it and please share your opinions and let me know what should I ask since this bike is in another league for me and I am trying to get to know everything that has been done to it
https://photos.app.goo.gl/jUY2jf4QToTvJAfp6
Thank you
PS before you guys start commenting about the windshield, the old man used to ever ride with snow, that windshield is already off....
Old 5th July 2019
Welcome to the XLForum...
Nice looking bike...
BE SURE TO LOOK AT THE CLOSE-UP PICS HERE!
Old 5th July 2019
dodgetrucken's Avatar
dodgetrucken dodgetrucken is offline
Sportster/Buell Model: xlh 900 custom
Sportster/Buell Year: 1964
dodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant future
Man I really like the scooter. All the little details are killing it on there from the signals mounted on the foreword controls, the oil cooler blinding in really nice in the front, the light up spark plugs (my dad had a set on his 52 panhead), the car wheel mounted on the back & even the home made baffling in the pipes to help with the drag sag. This was some ones baby & the attention to detail tells it all.
Sent from my SM-N960U using Tapatalk
Old 5th July 2019
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Other Motorcycle Year: 2015
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
That's an incredible looking bike man, nice find.
Where are you in S FL? I am working down in Ft Myers currently but live in the Tampa Bay area, I'm not the most knowledgeable person in regards to Ironheads but I'm a fair-to-middlin' shadetree mechanic in general and maybe I can provide some insight if you are close.
Old 5th July 2019
sleighcrane's Avatar
sleighcrane sleighcrane is offline
Sportster/Buell Year: 1967
Other Motorcycle Model: FLHR
sleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to all
As much as I am more into the stock looking bikes that is one cool sporty. Looks like it's a rocketship as well. Congratulations
Old 5th July 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Very nice custom, nice air horns, too. Welcome to the Forum!
Old 5th July 2019
That car tire will be an evil mistress.
Old 5th July 2019
NLXL's Avatar
NLXL NLXL is offline
Welcome! Woah, there's some expensive parts on that bike...Congrats and keep the rubber side down.
Old 6th July 2019
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Wow, pure Hollywood... Where to from here?
Sent from my SM-S767VL using Tapatalk
Old 6th July 2019
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Just an amazing bike, very nice find!
Sent with :-)
