0 can you tell me why?
0 .551 Cams in an EFI 1200
Last Post: Oldmxdog61u
0 Powervision autotune questions
0 Wont shift from 1st to 2nd
0 93 Sporty Key replacement
Last Post: oldboy
0 Tapered Muffler Baffle Repair?
Last Post: Hornsmith
0 what you think
0 1955 KH motor on E-Bay
Last Post: night-train
0 Kayaba forks no springs? Help with missing parts
Last Post: Bturkey
5 Tire Pressure?
0 Throttle Body loose
Last Post: MachU
0 Power cones
0 Wheels
Last Post: Merch131ho
0 What's your opinion on LED light kits?
0 clutchless 2003
Last Post: lehel
0 Super E knock offs?
0 American Flat Track revised 2020 schedule released
Last Post: Bow only
0 Spark plug discrepancy
Last Post: Ted Town
0 floor boards for rear passenger?
Last Post: Joe_jeep
Last Post: Joe_jeep
Old 19th November 2019
The list of parts that you have to remove from a 1980< XLH to remove the solenoid is to long to list, and too frustrating to think about
ferretface's Avatar
Here's another uniquely Harley-Davidson problem. The handlebars it came with were too wide to ride through the people-door in my one-car garage, so I bought a set similar but narrower. But the front master cylinder hit the speedometer gauge and the brake/throttle wouldn't slide on all the way - the banjo bolt hit the speedo.
So, after a member here pointed out that I could disassemble the speedo & tach without too much trouble, I removed the chrome gauge mount, cut one inch out of the middle and welded it back together, and re-installed the gauges. Now it fits through the door and the brake/throttle is on pretty much all the way.
Pic shows narrowed gauge mount with an OEM mount above it.
I can hardly wait for the next part that needs fixing/replacing.
class of 82 class of 82 is offline
Sportster/Buell Model: sportster xlh
Sportster/Buell Year: 82
Sportster/Buell Year #2: 82
Other Motorcycle Model: KZ 550
Other Motorcycle Year: 82
class of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to all
yes, it is fun fun fun I tell you!
IMHO, what I have read and have now done it is rather easy to work on.
I have had mine down and split cases for rebuild got screwed started over on my own and just bit the bullet and did it myself. I now have almost a 2nd E84 built from ebay parts and left overs now.
what I have learned is the 82 is the 25th anniversary for the sportster, 83 is a anniversary yr also the yr Harley was bought back from AMF.
IMHO-they did not screw it up again till the late 84-85 ironheads with the alt behind the clutch basket.
addicting also. I have 6 late model cyl heads/4 new cyls/2 primary set ups/ whole crap load of small misc stuff/3 complete wire harness-2 xlh 1-E84 roadster
working on a set of empty cases/trap door/primary & cam covers to build a 74 cubic inch stroker next
find a good machinist you can trust for the really important stuf and do the rest your self. only a couple special tools needed and most can be fabbed up at home.
sucks 4-5 things come off too do something but you get to know your sporty and you will find things before the are issues. like cracks/broke mounting tabs.
my rear MC was like that also. I got the 40" drag pipes and it only needed turned at the cyl port and adjust the rear pipe mount..got about a finger width
last of an era with 82/83/E84 ironheads.
paulc paulc is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
paulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond repute
Feels the same on my 76 too. On the plus side these bikes have a lot less of that than many. A friend of mine has a Ducati on which virtually any simpe job involves first removing many parts to gain access.
Paul
Sent from my SM-G935U using Tapatalk
Old 20th November 2019
ferretface's Avatar
OK, with everything connected as described in post/pics above (green alt + yellow alt wires connected to 'IG' on ign switch + white wire), I connected the battery and turned the ign switch to position #2. Oil pressure lamp came on but not the Gen lamp. Turned handlebar rocker switch to 'Run' and then hit 'Start' rocker. Engine turns over, still no Gen lamp. I turned ign switch to position #3, got F&R lights on plus Oil pressure lamp, no Gen lamp. Hit 'Start' and engine turns over.
My question here is - Should the Gen lamp be on with the engine turning over with it wired this way??? Showing that it has not reached the rpm where the alternator will charge the battery...
(The Gen lamp worked OK before removing the generator/regulator).
No tank or gas; cycle is in my house. If all had worked, I would open a door and connected gas tank w/gas and fired it up to check voltage. Ten inches of snow outside, taking it for a ride is not practical.
class of 82.july 4th 1981 the motor co.was bought back from amf.
saddlebagrail saddlebagrail is offline
Sportster/Buell Model: FLH Electra Glide 67/82
Sportster/Buell Year: 77
saddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to allsaddlebagrail is a name known to all
idiot light should be «on» when you turn the ignition and will stay «on» until the engine start ,then it will go out if connect correctly,mean system is charging correctly,those Poweraythor has been check in every step of the building process,friom start to finish and final test with load test and idiot light in line,I mean every single one of them has been check and test that way,Ray
ferretface's Avatar
That is what I had surmised from your instructions. Would you have any idea what I may have wired incorrectly??? Or what may still be wired but shouldn't be???
Old 21st November 2019
your idiot light have one or 2 wires ? and housing of the idiot light is metal or plastic ?
ferretface's Avatar
Looking up under the visor, I see two black wires going into a white plastic housing.
