Last Post: Oldmxdog61u
0 Powervision autotune questions
0 can you tell me why?
0 Wont shift from 1st to 2nd
0 93 Sporty Key replacement
Last Post: oldboy
0 Tapered Muffler Baffle Repair?
Last Post: Hornsmith
0 what you think
0 1955 KH motor on E-Bay
Last Post: night-train
0 Kayaba forks no springs? Help with missing parts
Last Post: Bturkey
5 Tire Pressure?
0 Throttle Body loose
Last Post: MachU
Last Post: Merch131ho
0 Power cones
0 Wheels
0 What's your opinion on LED light kits?
0 clutchless 2003
Last Post: lehel
0 Super E knock offs?
0 American Flat Track revised 2020 schedule released
Last Post: Bow only
0 Spark plug discrepancy
Last Post: Ted Town
0 floor boards for rear passenger?
Last Post: Joe_jeep
Last Post: Joe_jeep
  #241
Old 2 Days Ago
ferretface's Avatar
Originally Posted by paulc View Post
Since I started using pinniongears instructions when adjusting the clutch on my 76 I've found things to be much smoother. Never could quite get it right before but that way seems to work very well. Was going to find the link for you but seems i was too late.
Paul
From piniongear's post, I think it is posted in several threads. But Thanks! for thinking of me!
OK, I adjusted the clutch two times today. The first time, I made the clutch adjuster nut (NOT the cable adjuster nut) 1/4 turn out. That gave me a lot of slack at the handlebar lever, and no discernible ease in shifting gears. The second time, I tried 1/8 turn, and shifting seems easier (but still stiffer than last year) except for trying to find neutral. I still have to shut down and lift the lever into neutral by hand. But I'll try riding it around the yard to see if it has a special 'spot'.
I did notice that there seems to be a lot of slop in the handlebar lever pivot. Maybe the bushing? Or a worn pin-hole? I hate Harley handlegrips. The wires never want to go where I want them to.
But that will have to wait a bit. I discovered the answer to the question, "Can I lift a 550 pound motorcycle off my leg if it's on its side and I'm underneath it???". The answer is, yes. On the third try, after getting my leg out, and then figuring out which way to angle the front wheel, and then giving a good adrenaline-assisted lift to the bars. Hopefully, nothing was damaged, as the bike was shut down and I was dismounting when my jeans got caught. Except for a bruise or two, I'm fine, thanks for asking.
Old 2 Days Ago
If you are just riding it around the yard, it is not getting up to operating temp.
Cold Primary oil will dramatically affect clutch drag.
Old 2 Days Ago
ferretface's Avatar
I had not known that. Yes, just in the yard, 100 feet at a time. My area is hills & dales, if it breaks down, I'm not sure I can push it up a hill. Even if it's only 100 yds away.
Also...The Harley dealer ads say that only H-D primary chaincase oil should be used; anything else could affect function. Is that true??? Does it have special clutch friction plate additives??? I thought I'd 'break it in' with 20w50 Castrol motor oil. Is that bad???
Old 2 Days Ago
Primary specific oil does not have special additives, it in fact has fewer additives than motor oil.
It is the motor oil additives that some clutches may not like.
An 83 does not have a transfer valve so you can run chaincase formulated oil in it.
Oil discussions get religious so I'll avoid further comment.
Most important is fresh clean oil, before it's formulation.
What you use is a matter of personal choice.
