0 Greetings from Missouri!
2 Your daily tunes...
0 Air gap
Last Post: Aragorn
0 Spark plugs
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: Calcustom
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
0 DK customs suspension
Last Post: Bryan1976
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
Old 3 Weeks Ago
Mission1's Avatar
Mission1 Mission1 is offline
Mission1 is an unknown quantity at this point
Default Dynatek Ignition questions
I bought a dynatek ignition for my 74 iron head and there is some confusion on my end. #1 i can't see where the black points wire goes after the hole in the cone. Does the points wire to a breaker?! I know that the right side black coil wire goes through the frame tube and to the ignition breaker/timer. Is that the points?!The left side of coil is run/off switch(white) then grey to the ign. circuit breaker. I'm trying to make sense of where the points wire goes so i don't wire the new ignition wrong. Does the right side of coil run through the frame then down to the points?!
Mark Cunningham 74' XLCH Iron head
Old 3 Weeks Ago
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Is this what you have?
Stock sucks.
Traveled to
Old 3 Weeks Ago
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Moving to the Ironhead section, where you're most likely to get the help you want.
Folkie
South East England Riders
Old 2 Weeks Ago
the fsm would be a great help.
power from battery through main breaker to ign key sw
key on, power from sw to ign breaker, power to bar sw, from bar sw to ign coil, exits coil the points.
Old 2 Weeks Ago
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
Old 2 Weeks Ago
Mission1's Avatar
Yes that’s what I have!
Old 2 Weeks Ago
Not the best choice in ignitions.
No performance gain over points.
I won't install one as it retains the centrifugal advance.
Return it if you can and get an Ultima.
Old 2 Weeks Ago
CHOPTOP37 CHOPTOP37 is offline
Sportster/Buell Model: XLC
Sportster/Buell Year: 1972
CHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of light
the wire from the points goes thru the cone directly and only to the neg side of coil. the other coil term is swithtched 12v power . seems like you have a handle on this.
Old 2 Weeks Ago
rokytnji's Avatar
Black wire is usually condenser wire to points. It should be removed when points plate is swapped out the with the plate provided. Not sure where you black wire is coming from and only the blue and white wires are needed for hookup.
Old 2 Weeks Ago
Mission1's Avatar
Ya wish I could afford an Ultima at $174 I don’t have! Maybe someone in iron head forums has one they did t end up using. I can I longer return the dynatek.
