0 Front brake hose
Last Post: flthd31
0 2004 ICM
Last Post: tamaro
2 Your daily tunes...
Last Post: RDHenley
0 Exhaust pipes
Last Post: Joe_jeep
0 It's me - Kokopeli.
Last Post: Joe_jeep
Last Post: bill smith
0 Your trans/engine rebuild advice
Last Post: Bow only
0 Proper XLCH
Last Post: spamer80
0 chrome xlch bosch regulator cover
Last Post: 1968xlch900
0 Crank Seal Missing; Is My Engine Damaged?
Last Post: MkC
Last Post: keithnh
0 Greetings from Asbury Park, NJ!
Last Post: Bow only
0 Highway cruise speed
Last Post: xElvis
Last Post: RDHenley
0 Problem on a trip
0 Chinee Ignition
Last Post: RDHenley
0 900cc Pistons
Last Post: davixlrtt
0 Top End Whirring Sound
Last Post: Jason's Sporty
0 Simplified Wiring and Bars
Last Post: wannabehero
Last Post: RDHenley
0 TC88a help
Last Post: paulb
Old 2 Weeks Ago
CHOPTOP37 CHOPTOP37 is offline
Sportster/Buell Model: XLC
Sportster/Buell Year: 1972
CHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of light
very easy. the biggest hurdle for me is always getting the software to communicate with module. sometimes takes a lot of re trying, reopening, on/off ign etc. sometimes it works fine. tried several cables several laptops etc. once it communicates its pretty simple.
Old 2 Weeks Ago
Mission1's Avatar
Mission1 Mission1 is offline
Mission1 is an unknown quantity at this point
Is there a harness that I can USB into a laptop?! I saw a video that the guy was using jumpers for the wires needed in conjunction with a USB cable spliced open I assume to get the unit online with the software. How did you do it?!
Mark Cunningham 74' XLCH Iron head
Old 2 Weeks Ago
the proper cable from dyna tek is very expensive if your only doing 1 or 2 ign. theres a few guys on ebay /amazon selling nice cables for 20 dollars they work fine. ive never tried to splice/jumper a usb cable, too small wire for me to mess with and have no idea about how usb works. I figured better safe than sorry. I use both dyna and the ultima version quite a bit and since i primarily deal with kick only bikes this setting usually needs to be programed. also fair warning once progammed to any custom curves etc the dip swithches become inactive.
Old 2 Weeks Ago
the software is a free download from dyna also, just use the google machine
Old 2 Weeks Ago
Originally Posted by Mission1 View Post
What’s the difficulty level in the software end of an Ultima install?!
You do not need to reprogram an Ultima for street use on an Ironhead.
You should include a VOES for best street operation and easier starting.
Old 2 Weeks Ago
+1 on both points
Old 2 Weeks Ago
Mission1's Avatar
Name of the cable?! Best price found for the system?! Do I need there coil?!
Old 2 Weeks Ago
You don't need a cable.
eBay for the Ultima
It comes with a single fire coil if you buy the kit. (Buy the kit)
Old 2 Weeks Ago
Mission1's Avatar
you don't need a cable.
Ebay for the ultima
it comes with a single fire coil if you buy the kit. (buy the kit)
10-4! So how will I be programming it then and which kit is the exact one I need for a early iron head?!(74’ XLCH 1000)
Old 2 Weeks Ago
https://www.ebay.com/itm/Programmabl...9/161838367191
Top rated seller
https://www.ebay.com/itm/Standard-Mo...h/383538592663
Another top rated seller
Everything you need to know is in the manual that comes with it.
