0 what you think
Last Post: Hellbent_4
0 1955 KH motor on E-Bay
Last Post: night-train
0 Kayaba forks no springs? Help with missing parts
Last Post: Bturkey
5 Tire Pressure?
0 can you tell me why?
0 Wont shift from 1st to 2nd
Last Post: bmax13
0 Powervision autotune questions
Last Post: mastiffhound
Last Post: vaquerodiablo
0 Throttle Body loose
Last Post: MachU
Last Post: Merch131ho
Last Post: Oldmxdog61u
0 Power cones
0 Wheels
0 What's your opinion on LED light kits?
0 clutchless 2003
Last Post: lehel
0 Super E knock offs?
0 American Flat Track revised 2020 schedule released
Last Post: Bow only
0 Spark plug discrepancy
Last Post: Ted Town
0 floor boards for rear passenger?
Last Post: Joe_jeep
0 93 Sporty Key replacement
Last Post: Joe_jeep
  #71
Old 5 Days Ago
Smerch's Avatar
Smerch Smerch is offline
Sportster/Buell Year: 1979
Smerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to behold
There's a big thread in the stickies about Ultima mapping-
http://xlforum.net/forums/showthread.php?t=1757704
Are you buying a cable to program your ignition when it shows up?
Old 5 Days Ago
Mission1's Avatar
Mission1 Mission1 is offline
Mission1 is an unknown quantity at this point
Cable came today!
Mark Cunningham 74' XLCH Iron head
Old 4 Days Ago
Mission1's Avatar
I read that, but he didn't mention what kind of setup he was running which i thought would be important to mention for reference! He mentions that not all setups are the same as would be his but not touching on that we have no real reference to start with. I suppose specific to his setup using a Voes suggesting later 70's into the 80's evo. Mine being a 74 xlch kick start will use zero dead rev's. I did get a VOES in case it's needed but that requires drilling into my SS E manifold.
Old 4 Days Ago
Originally Posted by Mission1 View Post
... I did get a VOES in case it's needed but that requires drilling into my SS E manifold.
I drilled mine. The first part was to find the thickest part of the manifold to install which would also be a convenient location. I was going to use the marked spot on the back but decided against it...
Try to get one of these, a vented cap screw, a somewhat common automotive part...
Old 4 Days Ago
Mission1's Avatar
Did you find that the VOES was very beneficial and necessary?! I hope this one is the correct one if so! What size drill and tap?!
MC-V0S3
Old 4 Days Ago
It needs only a tiny tiny hole in whatever part you insert. If you can get one of those vented screws from an auto supply that would be easiest. Just get the smallest one they have and drill and tap to fit the screw threads.
When you decide on the spot to use ensure that it will not interfere with the mounting arrangement
The engine performs better with the VOES. I was using Wiseco 10:1 pistons and had to work at eliminating the pinging. The VOES was a help. I just trust the overall performance was better. Hard to judge. All that f@cking racket from the engine
Old 4 Days Ago
Mission1's Avatar
I’ll keep that in mind! Weisco is a few cities away from me in Ohio and I used their pistons for my VW project! If you e used the Ultima is there a stick map used to start with?!
Old 4 Days Ago
I do not know the terminology "stick map". With the Ultima for a street bike, just install, set static timing and go.
Old 3 Days Ago
Mission1's Avatar
Did I say Stick map?! Lol I meant Stock map settings!
