0 Air gap
Last Post: Aragorn
0 Spark plugs
0 Greetings from Missouri!
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: Calcustom
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
2 Your daily tunes...
Last Post: RDHenley
0 DK customs suspension
Last Post: Bryan1976
0 Polished rotor/brake pad compatability
Last Post: RDHenley
0 '81 swingarm internals
Last Post: Scott
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
Default Intake manifold
Im building a 1974 XL
It came with a cast iron intake manifold
I want to run a aluminium one (I found in my parts stash)
Because I can polish it
Opinions, pros - cons
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
doodah man's Avatar
I think as long as you have an insulator between carb and manifold it won’t pose any problems either way. What carb?
if it is a cast, does not polish well. use fine grit and lite pressure as soft aluminum will streak gouge easily.
wear a mask if you do not want a nose full if aluminum.
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
It will still absorb some radiant and convection heat from the head but not significant.
You can blend in the radius inside the back wall to improve flow a bit.
Originally Posted by doodah man View Post
What carb?
Bendix
I have 2 to (hopefully) get 1 good
do not waste your time polishing the insides, intake actually does better with a little roughness, the exh side does better. main thing is that the port to port lines up well, which sometimes requires you to loosen the heads.
the vm round slide mikuni works wonders here, i run the 38mm but should have installed a 40mm. kicking butt since 1975.
Who must be wrong:
Jerry Branch
Dick O'Brien
Clyde Denzer
C. R. Axtel
dynamometer
mrmom9r's Avatar
mrmom9r mrmom9r is offline
Who must be wrong:
Jerry Branch
Dick O'Brien
Clyde Denzer
C. R. Axtel
dynamometer
Those old grey breads were wrong . We now know a rough finish is preferred and it hasn't been a secret for at least 20 years.
I recall reading an article many years ago where Branch said he knew that the high polish wasn't really effective but he did it anyway because customers were so impressed by the way it looked.
very hard to tune a short intake with one hell-of-a reversion when the intake closes, flow pretty much stops for a milli-second or so. sticks burn better than logs so a little roughness helps break things up.
now if you have to remove material from either side to get a very good alignment, go for it. however, most really do not care and the ole iron putts on merrily for over 1/2 century.
