0 Greetings from Missouri!
Last Post: Veeflys
2 Your daily tunes...
0 Air gap
Last Post: Aragorn
0 Spark plugs
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: Calcustom
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
0 DK customs suspension
Last Post: Bryan1976
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
belly, vin
Dave Walters Dave Walters is offline
Sportster/Buell Year: 1976
Dave Walters is an unknown quantity at this point
Default 1000cc engine with missing right side vin. Belly and Primary stamp pics
I just got this engine from a pile of parts a racer guy had. The engine has "1964 XLCH" stamped on the right side where the factory vin should be. My thoughts are a racer trying to run a 1000cc motor passing it off as a 900cc early model. It was setup in a frame with the right hand shift.
The number stamped in the primary is 775253080 and the belly numbers read 77424748 but are crossed out and someone stamped 775253080 to match the primary stamp is my best guess.
Do the belly numbers look factory (minus the fact they are crossed out) and is it weird to have the primary number read a 775 prefix while the belly is a 774?
Link to pics in next reply
https://imgur.com/a/ZGrXKuk
https://imgur.com/a/EiDFqRx
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
Maybe, but I really doubt it. They are too many other "tells" to distinguish a 900 vs 1000 cc motor.
How about posting pics of the left & right side cases ?
Are belly numbers really relevant? Also, Those seem quite long...
The lack of a legal motor number is more disturbing.
If the motor number pad has been altered you may have issues.
I'd venture that if you want to put it back on the road you will need a numbered frame.
And it may not get titled as a HD....
I don't have pics right now of engine. (It is at home I am at work)
I know it is a 1000cc later model engine.
Where the right side vin should be is ground off and restamped with the "1964 xlch"
My main concern is the 775 and 774 prefix differences from the primary and belly numbers. Also would any of the numbers in the belly or primary match the vin numbers that would have been on the engine?
I have a numbered frame that is 1976. Going through title work process so they will want to inspect the engine number which it doesn't have.
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
The 1964 left case doesn't have a starter bulge above the clutch, all 1000cc engines do.
IIRC the NATB book shows where the VIN is on 1964.
Possible: auction title cleans everything up.
I, in no way, think this is a 1964 motor. That is simply what someone else stamped on it.
I believe you.
I believe you. I was only asking for the pics to see what I could pick out in the way of "tells" on your motor.
Have a careful read thru this link:
http://sportsterpedia.com/lib/exe/fe...nkcase_ids.pdf
Pure speculation on my part:
  • if you can believe the info presented, it would appear your cases were created Sept 4, 1974 (for the '75 model year).... got shelved for whatever reason then came back to life in Sept 10, 1975 (for the '76 model year)
  • OR (and probably a more likely scenario)
  • were incorrectly stamped on Sept 4, 1975 (with a 1974 date) and were re-stamped 6 days later with the correct Sept 10, 1975 date (for the '76 model year)
No. Not as far as I know anyway.
Last edited by The Doctor71; 1 Week Ago at 18:12.. Reason: corrected Julian date calculations
I wasn't suggesting that you were deceived, only that the error is VERY visible and easily detected by DMV, ATB, etc.
