0 Air gap
Last Post: Aragorn
0 Spark plugs
0 Greetings from Missouri!
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: Calcustom
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
2 Your daily tunes...
Last Post: RDHenley
0 DK customs suspension
Last Post: Bryan1976
0 Polished rotor/brake pad compatability
Last Post: RDHenley
0 '81 swingarm internals
Last Post: Scott
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
ilbreizh ilbreizh is offline
Sportster/Buell Model: xlh1000
Sportster/Buell Year: 1979
Other Motorcycle Model: lambretta 125m
Other Motorcycle Year: 1948
ilbreizh is an unknown quantity at this point
Default LePera solo seat (art.L855) on '79xlh ironed
hello everyone, I bought a LePera saddle for my ironhead, I tried to mount it on the frame and it fits well, but ... the fender does not have the fixing hole ...
is it possible?!
I hadn't noticed until I tried it.
have you had such experiences, how did you solve, did you make the hole?
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
I'll move this to the Ironhead section, where you're most likely to get the help you're looking for.
Folkie
South East England Riders
thanks, I still have to settle in the forum
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
How about some Pictures?
https://imgbb.com/
Stock sucks.
Traveled to
yes!!! thank you
https://imgbb.com/
Originally Posted by ilbreizh View Post
yes!!! thank you
can't see the pics ... what did I do wrong?
Folkie's Avatar
Brass Nut
yes!!! thank you
Here you go:
Pics are huge, so I didn't post them full size. (resize before uploading)
rokytnji's Avatar
Yeah. Latest image upload piece should work. I usually remove the fender but it is not needed to be done. Just remove wheel . Tape up fender where you are going to drill the hole < so as not to chip paint > . Use the right drill bit for a snug fit. Have at it.
I usually either weld a nut using a torch and brass rod or pick up a rivet blind nut from the hardware store.
Here you go:
thank you very much, i will learn
