0 Greetings from Missouri!
2 Your daily tunes...
0 Air gap
Last Post: Aragorn
0 Spark plugs
Last Post: rubine
0 Crane HI4 ignition question
0 Huge pile of Ironhead Parts
Last Post: Calcustom
Last Post: motorfish
0 Corbin Hollywood Solo / Matching Passenger Pad?
0 Gel in seat for rigid?
Last Post: 84bobber
0 RIBSTER PRIMARY? 2004 up vs 2001?
Last Post: FiftySixer
0 What Year Range of Heads & Cylinders?
0 883 Highway Speed?
0 Hello from LA
0 Good afternoon!
0 It's me - Kokopeli.
0 New guy from Georgia
0 Other Than Black XL Book
Last Post: RDHenley
Last Post: Bow only
Last Post: RDHenley
0 Completely Chromed 10.5" Rear Lowering Shocks
3 Ironhead Pictures Thread
Last Post: Kokopeli
5 Terminology Sticky?
Last Post: XLtimes
0 DK customs suspension
Last Post: Bryan1976
0 Polished rotor/brake pad compatability
Last Post: RDHenley
jeffcahill (67), jeebus (52), cdepaola (50), RubenAlonzo (50), chida66 (45)
ferretface's Avatar
Default Shift Lever Interchange ???
(Not clutch lever!)
Even if I get my shift problems sorted out, my foot still doesn't turn down enough to shift comfortably. What I ideally need is a steel shift lever for my 83 XLH so I can heat it up with a torch and bend the toe up more.
Does the 86 shift lever fit an 83??? Both the lever and the shaft have the same 5-digit part number, just the 2-digit year suffix is different.
I couldn't find a steel lever for the 83 but Drag Specialties makes one for the 86. Is the spline the same??? (My dealer doesn't know).
Thank you for your help!
doodah man's Avatar
May be easier to go with forwards?
a picture says a lot. one piece or two???
ferretface's Avatar
I think you got the wrong thread...
ferretface's Avatar
V-Twin Mfg makes one...
V-Twin Manufacturing
Chrome Shifter Lever - 34606-77
Part #: 5702056
Mfg Part #: 34606-77
Chrome shifter lever constructed of steel includes a 1/4" x 20" x 1" screw with lockwasher.
OEM No. 34606-77
Item is Out of Stock
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Model: Ducati
Other Motorcycle Year: 1974
oldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond repute
easy to find on Ebay....
2006 1200c: Home Made a/c, Cycle Shack Slipons, Daytona TC88A w/JesterVII map (thank you, Rico), Street Trackers
ferretface's Avatar
But unable to tell from aluminum. Sellers are showing the same pic & description but not what the material is. The cheap Chinese aluminum levers look like they fit the spline but are just a few thousandths undersize. I have one of those if you'd like it - just pay the postage and I'll send it out.
V-Twin part number is 21-0304, made of steel: https://www2.vtwinmfg.com/shifter-lever-chrome-2.html
Easy to find at lots of places, for around 20 bucks...
https://www.google.com/search?client...4dUDCAs&uact=5
Hazmat Life
ferretface's Avatar
Thank you for your help! I ordered one!
If anyone wants the new unused aluminum Chinese lever, shoot me a PM and for the price of postage, it's yours!
oldboy's Avatar
sorry for the late reply! It's great you found one. The first one my Ebay search turned up was listed as made of steel.
