0 can you tell me why?
0 .551 Cams in an EFI 1200
Last Post: Oldmxdog61u
0 Powervision autotune questions
0 Wont shift from 1st to 2nd
0 93 Sporty Key replacement
Last Post: oldboy
0 Tapered Muffler Baffle Repair?
Last Post: Hornsmith
0 what you think
0 1955 KH motor on E-Bay
Last Post: night-train
0 Kayaba forks no springs? Help with missing parts
Last Post: Bturkey
5 Tire Pressure?
0 Throttle Body loose
Last Post: MachU
0 Power cones
0 Wheels
Last Post: Merch131ho
0 What's your opinion on LED light kits?
0 clutchless 2003
Last Post: lehel
0 Super E knock offs?
0 American Flat Track revised 2020 schedule released
Last Post: Bow only
0 Spark plug discrepancy
Last Post: Ted Town
0 floor boards for rear passenger?
Last Post: Joe_jeep
Last Post: Joe_jeep
Old 2 Days Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Some just run drag motors on the street in the rpm they were built to run at. Not ever giving a crap about what goes on at 25-3000.
Old 2 Days Ago
Sportster/Buell Year: 1969
RicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to behold
Originally Posted by ryder rick View Post
Torque cones are like yelling with your hand over your mouth.
From a performance standpoint I would never install them.
Drag pipes suck. There are no band-aids that can be applied that can recover what is lost.
Drag pipes are the problem, the solution is NOT to add more problems to the exhaust.
Sticking things inside a Drag pipe is like trying to fart around a cork.
Guys who insist on using Drag pipes do not care about performance.
I'm currently running 40 inch long 2 inch drag pipes with full baffles inserted. Have not put bike on dyno because it's not broken in yet. Seat of the pants performance is good. Why am I running the worst pipes for the street? I'll tell you why, they don't make 2 into 1 pipes for Ironheads anymore. I've phoned several manufacturers and they tell me there's no market for them. Guess what? Everybody sells drag pipes.
Old 2 Days Ago
as far as the cones not fitting in an ironhead exhaust.i bought a set for an evo and turned .040 off the o.d. and they were a nice tight fit in the pipe up against the exhaust spigot.after i got my XLR heads back from mrmom9r i was blowing the pipes off with the big valves and port work.he told me to lose the cones..i did.
Old 2 Days Ago
"Guess what? Everybody sells drag pipes."
Doesn't make it right or the only choice, and you are pissing into the wind.
It's the same reason many of the re-pops of OEM parts are available in Chrome only.
You can lead a horse to water,....
Tradition (even when it is wrong), ego, and wet dreams trumps making correct choices on a daily basis.
Then the bean counters come along and look at sales figures and decide that because 2:1 pipes are not selling near as much as Drag pipes they will no longer have them made.
So in effect you are causing the problem that you are complaining about.
Don't buy drag pipes unless you are using them as a donor to mash up a decent exhaust.
There are brand new header pipes available if you look for them.
I took an EVO pipe and grafted on Ironhead spigots now I have a nice Supertrap for an Ironhead.
There are 2:1 mufflers sold that will fit drag pipes, if all you have is a hammer and a hack saw to work with.
Old 2 Days Ago
Ryder Rick I alone have only purchased 1 set of Ironhead Sportster drag pipes in the last 40 years. Hardly an impact on market research and bean counters. The last Sportster I owned was in 1975.
Old 2 Days Ago
Originally Posted by BigMek View Post
..I'm definitely no expert on the subject...
The only thing I found wrong with this post was the first sentence. "No expert?" I'd say you're close. A very good understanding of a complex system. Great post.
Old 2 Days Ago
Another problem with HD pipes is packaging, trying to fit something that actually works in a limited space.
Old 2 Days Ago
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
My '71 iron head is nowhere close to a 'drag motor'. It's a 900 cc bored .030" over to clean up the cylinders. PB cams and a good ol' Bendix on a cast iron intake manifold.
My pipes, each less than 16" long, were made with the board tracker look in mind.
I figured they'd be loud so I bought a set of 8" universal baffles and reshaped them into a curve them so they'd slide up into the pipes.
Everybody (me included) is surprised at just how quiet they are. The video is inside my storage container so they're even quieter out in the open with no metal walls to reflect the sound back at you.
https://www.youtube.com/watch?v=NUNi...ature=youtu.be
"If a camel flies, no one will laugh if it doesn't get very far".
Old 1 Day Ago
Jones: your situation is different you built a certain stye of bike and are happy with that outcome.
You are not crying about poor idle and low speed performance.
You understand the consequences of what you built, and if you don't like it you will change it.
Old 1 Day Ago
Very true, Rick. Thanks for the kind words.
