0 can you tell me why?
0 .551 Cams in an EFI 1200
Last Post: Oldmxdog61u
0 Powervision autotune questions
0 Wont shift from 1st to 2nd
0 93 Sporty Key replacement
Last Post: oldboy
0 Tapered Muffler Baffle Repair?
Last Post: Hornsmith
0 what you think
0 1955 KH motor on E-Bay
Last Post: night-train
0 Kayaba forks no springs? Help with missing parts
Last Post: Bturkey
5 Tire Pressure?
0 Throttle Body loose
Last Post: MachU
0 Power cones
0 Wheels
Last Post: Merch131ho
0 What's your opinion on LED light kits?
0 clutchless 2003
Last Post: lehel
0 Super E knock offs?
0 American Flat Track revised 2020 schedule released
Last Post: Bow only
0 Spark plug discrepancy
Last Post: Ted Town
0 floor boards for rear passenger?
Last Post: Joe_jeep
Last Post: Joe_jeep
Old 1 Day Ago
back pressure a bad thing is a blanket statement and is not necessarily true in all situations. every engine is diff. for ex: if you run an expansion chamber open, the engine suffers, the stinger or exit port which is a controlled bleed in very important.
an engine only has a band of power and is shaped by how it is configured, the exh ONLY compliments it.
each exh bandaide has it +/-'s. church key cuts, perfs, flow thru perfs & blind perfs operate diff and is controlled by size.
when i up the ole 74ch, i had issue with all of them, could solve one problem but create another, before it ran flawlessly even though not to max capacity. after studying commercial exh systems, i tried a change in direction concept. high performance exh do not restrict with the above, they use a radius bend. the thing about exh and pressure waves is the DO NOT like changes in direction as the waves are straight lined.
after toying with diff ideas, i made a set of twisted baffles and now my upper & lower play nice and the exh note is pleasant. it also fights reversion since it too does not like change of direction.
Old 1 Day Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
Which oil should I use to control reversion ?
Old 1 Day Ago
spacecoast spacecoast is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant future
Lol.
Old 1 Day Ago
GMC W4500 Forward engine oil
or
Oneway Racing Max 5w-40
Should take care of it.
Old 1 Day Ago
I have been using Mazzola for a decade now with good results.
Old 1 Day Ago
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
Yeah Mick. I've heard Mazzola found its calling in 1948 to 1965 big twins--
...'cause it doesn't stick to the pan. Nyuck, nyuck, nyuck.
"If a camel flies, no one will laugh if it doesn't get very far".
Old 1 Day Ago
i use to run a suzuki b100p and i would on occasion add some the gas tank, everyone around always said man who's making pop corn, and that is no corn.
Old 1 Day Ago
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Still trying to grok why ice-cream has no bones, myself.
Stock sucks.
Traveled to
Old 1 Day Ago
kitabel kitabel is offline
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
Exhaust gas (the molecules) has considerable inertia during engine operation, but still reverses into the chamber during overlap and low RPM.
The pressure wave (not the gas) reverses back up the pipe to the exhaust valve when it reaches a big change in cross-sectional area.
If the change is to zero (open megaphone or drag pipe) it reflects with its sign reversed (positive becomes negative). According to Blair, more than 2-1/2 X the ID is the same as fully open.
If the change is a big restriction (reverse cone or a flat plate) it reflects with the same sign (remains positive).
Jennings "2 Stroke Tuners Manual" has great data on this.
Old 13 Hours Ago
mrmom9r's Avatar
Infused ?
