0 words fail me
Last Post: Oldrump1
0 C.O.B.B run west
Last Post: Dustpan63
0 Spokes or Mags
Last Post: tomaso
Last Post: big andy
Last Post: Crash7557
0 Flat tracker pics
Last Post: Commando
0 Help With Oil Flow
Last Post: brianbbs67
0 Riding the Heat Wave!
0 To seal or not to seal!
0 Wheel bearings
Last Post: cotton1
0 19 years and counting
Last Post: IronHeadRon
0 How is 1969 xlch voltage dispersed and regulated.
0 Your Favorite Style
Last Post: tigger
0 1998 Sportster Ignition Problems
Last Post: Larry May
0 Battery Life
Last Post: Four Speed
Last Post: garcia2389
0 When Were You Born?
0 Lost kicker stroke, is it normal?
Last Post: WI_duker
5 Is side stand frame break not an issue Kickstarting??
0 Black Rain?
Last Post: denguy
0 It's Ireeman's birthday
90ci, big bore, engine builder, hammer performance, patriot defender
  #1531
Old 6 Days Ago
cycowrencher's Avatar
You're better off reducing the base gasket height.
Old 6 Days Ago
MatHormell's Avatar
Sportster/Buell Model: XL883R
Yea I could go with either, running 0.020 base currently.
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
Old 6 Days Ago
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
Originally Posted by MatHormell View Post
I have a few changes in the works.
First and foremost I have to repair my tail section and build a better support system to hold it.
I also need to design and build/ weld mounts for a chain guard, going to hang it from the frame, rather than mount it to the swing arm.
I am also thinking I am going to do some testing on the motor. I am going to swap out the 1.725 high ratio roller rocker arms from the exhaust valves and run standard ratio on Exhaust and the high ratios on Intakes. This is just for testing purposes to see what kind of difference it makes.
In addition to the standard ratio arms on the exhaust valves, I am going to drop my head gasket down a size from the current 0.030 to a 0.020. My squish was between 0.045 and.043 in most places so looking to tighten that up closer to .030 and get a small compression bump out of it.
Other things in the works for the near future is a 32T aluminum crank sprocket to get my final drive ratio closer to where I am wanting it. Hopefully I can get cracking on all this very soon, plans to be ready to TNT by mid September and make the Last Bowling Green AMRA Race.
If I’m breaking mounts I would check the crank runout. I’m running somewhere around .035/.038 squish. Was thighter last year but found the piston rock might have an issue so backed it off .010 and coated the piston skirts. Looks good so far. Seems like you can get a tighter squish with the 1250 bore/aluminum cylinders. I ran really tight with that set up, gotta warm it up good tho. Curious to see how much piston rock you have after running it in.
Old 6 Days Ago
MatHormell's Avatar
Yea I spoke with dan and he agreed 0.020 is to small with the cast irons but should be good with a 0.010 base and ending up with a 0.035 squish. Since its base I may just finish out the season as is, and make the engine changes this winter during down time, that way I wont be rushed and can inspect everything more thoroughly
Old 6 Days Ago
MatHormell's Avatar
I'm not breaking mounts if that's what you meant
Old 5 Days Ago
MatHormell's Avatar
Mac, How many CC of dome is your piston? and what CC are your chambers?
Considering having new pistons made this winter with a bit more dome to them, curious what your running. Mine came out to 22cc dome/ 91cc chambers
Old 5 Days Ago
rocketmangb's Avatar
I think ya need mo dome Matt !
I think my 1250s are 17 with 81cc chambers
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 5 Days Ago
MatHormell's Avatar
Ya that will be the end result for sure is going with new pistons. I was playing it safe before and more focused on street and strip, but now Im planning to build for track only, Hopefully can squeeze 150 out of it with more compression, But that will be much later this coming winter.
Old 5 Days Ago
HaHa, not going to believe this but I’m cleaning my garage and watching those boxes and that info burn on the bon fire right now! I leave it up to Aaron and Dan and just tune what they send me. If you talk to them they may have it in their records. I did write down the corrected ccp according to the formula on their website, 11.8, if that helps. That’s all I have, just a bracket guy working with what I have to give us what we need. IMO theres definitely more in the combo if that’s what you’re looking for. It’s giving us the consistency/mph we need so we’re not stepping on it.
Old 5 Days Ago
MatHormell's Avatar
Haha, all good just kicking around ideas and options right now, motor is running awesome as is, going to finish out the season and make some adjustments this winter
