0 XR mutt race bike progress
Last Post: Scott
0 Top end failure
Last Post: Tipofthelake
8 Inexplicable miss
Last Post: gwcrim
5 Eye Protection When Riding?
0 Ignition advice
Last Post: Rhode Warrior
0 1992 XL ignition explained
Last Post: Bwf347
0 Proven external Fuel pump and regulator
0 41mm V-Twin Narrow-glide conversion for XL
Last Post: keithnh
0 New guy from IL
0 normal shifter shaft wobble
0 Front Brake Upgrade
Last Post: keithnh
0 Chinese S&S carbs
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 Bandanas
Last Post: Padre
0 Top end reassembly...what goes where!?!?!
0 3/4” Axle Drum Brake ??
0 UltraCool oil cooler safety concern
14 I just kind of stumbled in here... like 100 times.
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
warpusher, Terp84Alum, FiremistSLK (74), moony956 (72), E.H-57 (63), bplinson (56), fbroos73 (47), prefect (40), bamf_shadow (38), jakebuganski (38), Arwalkz007 (37), Fraser19 (31)
Old 4 Days Ago
11B40 11B40 is offline
11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of11B40 has much to be proud of
I ran a stock GAL on my 55" 66 for quite a while. It was just beautiful compared to the Tillotson and as Capt said the mileage improved dramatically. As I reported sometime back, we ran the motor at Fremont Drag strip and Tillotson to GAL, the bike picked up 10 MPH. My friend Jim spent a morning trying to beat another friend's Kitted Honda 4 and kept getting beat by a length. The engine is a 72" stroker '64. Jim went home took off the DL and put on his GBL came back and beat the Honda by 2 every time they raced.
