0 45740-62 & 62A differences?
Last Post: Fridge
0 Need to part with my '59
0 When Were You Born?
Last Post: owlsplace
0 Lowbrow XLR pipes
Last Post: A Seabee
0 Question for RB racing exhaust guys/gals
Last Post: 883sporty03
0 Efi and carbs
4 Hello from Chicago
Last Post: Thirdbrick
0 Hi
0 What Petcock
0 Which cams ?
Last Post: Cumofo
0 Kickstarter return spring
Last Post: JonesL
Last Post: A Seabee
0 Hi everybody!
Last Post: big andy
0 Sell pricing for 1979 XLS IH Sportster
Last Post: RoadsterMike
Last Post: motorend
Last Post: dieselvette
Last Post: Renecito
0 7 Dead and more wounded
0 Let's See Them R's!!
Last Post: PetesPonies
0 Riding in The Heat!
Last Post: motorend
Last Post: Clevspeed
0 Stock Seat 48!
0 Fantasy Football League
richard rees (70), IRONHD1K (66), derekb (58), Hankrebel (43), CPurner (38), Vickers
  #51
Old 11th May 2019
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
These engines can idle as low as 7-800 rpm. Don't do that though, it's too low.
I the timing isn't right, then no, t won't idle/run properly. Thebike only needs to ve able to run at 2000 rpm to set the ignition with a timing light. A timing light s the only real way to set the timing. Static timing only gets you close. It should be 40 BTDC at 2000 RPM
If you have compression over 120 PSI on both cylinders and you have the timing set correctly and the idle circuit is working the bike will happily idle at 1000 rom.
Again, the idle speed is NOT set with the idle screw. The idle speed isset with the stop screw on the throttle.
I suspectthat if you turn out your idle screw another 3/4 turns things will change.
Old 15th May 2019
4th of July's Avatar
4th of July 4th of July is offline
Sportster/Buell Model: XLH 1000 cc
Sportster/Buell Year: 1976
4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light4th of July is a glorious beacon of light
Again, thanks for sticking with me on this. Most of you guys, if not all way above, are above my technical level on these bikes. I have done some partial carb rebuilds on old Chevy Nova's but real basic stuff like replacing needle seat that controls gas flow to bowl, replacing gaskets, etc. With this bike, which is about the same age as the Nova's (73) I really don't know what I'm doing, except in principle, and don't want to mess something up in the process.
Anyway, I don't think the increased diameter fuel line did it, just temporary. Bike will start right up, run for a minute or so then shuts down. I still believe it is fuel flow. I hit the bowl with screw driver handle let it set for a bit, then it fires right back up. Before tapping the bowl like that it would not always fire right back up. FLOAT "appears" to be sticking, my best guess, which someone already said.
I put some carb cleaner/lubricator in tank, but is there something you all would recommend if I go that easy route? If not I need to disassemble this 73 Bendix carburetor. If there is any critical advice on how to do that, and then resealing it back up, please let me know. Thanks again!
Old 15th May 2019
doodah man's Avatar
There’s really nothing to taking a bendix carb apart if you feel that’s what it needs. Way simpler than what you had on that nova, I’m sure. After all, it’s just a handful of screws. Don’t over tighten the main jet tube, it can crack the float bowl.
http://xlforum.net/forums/showpost.p...2&postcount=30
Old 15th May 2019
I am still pretty sure it's just the needle/seat. That's probably all you need to look at inside the carb. Cheap enough to buy a replac,emt. Probably just the needle in fact. Willing to bet it's a "viton" tipped needle.
Old 15th May 2019
Have you checked for power to the coil? (Test light)
Maybe a Circuit Breaker or something is opening up?
If it is a fuel issue it would slow and sputter to a stop, and electrical issue will shut it off clean (usually).
Old 15th May 2019
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to beholddavixlrtt is a splendid one to behold
The float spring can be installed in such a way that it will actually cause the float to push upwards against the needle instead of acting as a helper to drop the float.
.......Davi.
Old 16th May 2019
Thanks guys, will check it out. If I get a definite fix, will let you know. Lots of experience on here, really appreciate it.
Old 21st May 2019
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
.......Davi.
got my vote, the wire leg on the spring needs to be down on the inside of the bowl, also sounds as if the pilot circuit is plugged, my favorite carb is the bendix on ironheads and shovelheads, if done correctly it'll turn up to 5,500 rpm in 4th gear and that's hauling ass hahahahahaha, most of the aftermarket kits have junk parts though, if you can find the superior kit they work well, or get the more expensive us made bendix zenith kit.
I'm not a complete idiot, some parts are missing.
Old 21st May 2019
doodah man's Avatar
Arrow
Right, with zenith fuel systems still being in business, I’d go for the original. Then you know it’s right. Price isnt such a big deal when it’s likely to be the last rebuild kit it ever needs.
