0 45740-62 & 62A differences?
Last Post: Fridge
0 Need to part with my '59
0 When Were You Born?
Last Post: owlsplace
0 Lowbrow XLR pipes
Last Post: A Seabee
0 Question for RB racing exhaust guys/gals
Last Post: 883sporty03
0 Efi and carbs
4 Hello from Chicago
Last Post: Thirdbrick
0 Hi
0 What Petcock
0 Which cams ?
Last Post: Cumofo
0 Kickstarter return spring
Last Post: JonesL
Last Post: A Seabee
0 Hi everybody!
Last Post: big andy
0 Sell pricing for 1979 XLS IH Sportster
Last Post: RoadsterMike
Last Post: motorend
Last Post: dieselvette
Last Post: Renecito
0 7 Dead and more wounded
0 Let's See Them R's!!
Last Post: PetesPonies
0 Riding in The Heat!
Last Post: motorend
Last Post: Clevspeed
0 Stock Seat 48!
0 Fantasy Football League
richard rees (70), IRONHD1K (66), derekb (58), Hankrebel (43), CPurner (38), Vickers
Old 20th May 2019
Disturbediwv Disturbediwv is offline
Disturbediwv is an unknown quantity at this point
So it turns out that all of the inner cam gear bushings are loose and slide right out. Two of them are pretty wobbly. I dont understand how or why they would be so wobbly.
The outer bushings are also not with the slot facing up, but they are at least tight in there. I wonder if someone previously installed them incorrectly and they weren't getting oiled.
Those bushings are $30 each. What a bummer.
Sent from my SM-G960U using Tapatalk
Old 21st May 2019
This is the way the bushings are configured originally in the cover.
The FSM says, when replacing the bushings, there is no certain way the slots should face with the small bushings.
Although it's debated whether that's actually an issue.
The inner bushings are a press fit. They should be tight like the ones in the cover.
Chances are, the case bores are wider than they should be now.
You may get a standard bushing back in there or may not.
I'd mic the bores to see if they are all the same I.D.
These are cylinders but the process is the same.
Just using calipers won't be as accurate.
If one or more are compromised, chances are the bores won't the same size.
If this is the case, try and find some oversized bushings.
There may be oversized ones out there still for a Sporty but I don't think so.
Try McMaster-Carr or someplace like that.
But, then again, you haven't seen the inside of the case yet.........
Old 21st May 2019
yep, mr. hippy, that was a GOOD discussion with a lot of info +.
now there are some things to consider and whether they can be applied or not.
new cover or case
custom bushings
conversion to torringtons
swedged bushings. a process where the bushing is expanded to fit the bore and then sized.
it seems the ole iron with pinned bushings has some merits
Yeah there has been a lot of good discussion and information here. You guys have helped me out and I appreciate it.
I'm just going to sell the bike as it is. Thanks again gentlemen.
