Last Post: Gulf Coaster
0 What engine oil do you use?
0 big bore kit
Last Post: duffy
Last Post: duffy
0 Indian FTR Sales
Last Post: duffy
Last Post: savagegarden
0 It's stalkie's Birthday!
Last Post: priell3
0 ARCH motorcycles and more
Last Post: RDHenley
0 Un-lowering my Super Low
0 A Day in the Life...
Last Post: RDHenley
0 Hack or trike?
Last Post: RDHenley
0 signature pic
Last Post: stikflote
Last Post: Kbetts
0 '59 XLH - Speedo cable route
Last Post: Guidorey
Last Post: waiteitei
buddy (66), paulrainer (66), Pedrochellie, needweknow, BunnMan (48), SolariS (43), Doc69 (39), ftptptt1234 (39), dumbmxer84 (36), nhutch40 (28), XLButler (21), Ztomasc (21)
Old 15th December 2019
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
True statement "all the little bits add up after awhile". Some mods while minute actually improve effects from other mods thus compounding result. The opposite can also be seen in deferring maintenance or allowing a small problem to go unresolved.
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
for my race engines I do whatever i can. It's just a matter of economics.
For me, the true cost of racing has to include not just the price of the engine but everything it takes to get us to the start line.
That means:
Transportation, accommodation, entry fees, fuel, spares etc.
We cam travel 4,000 kilometers for some race meetings. I can't afford to get there and have o miss a race (or the whole meeting) on account of some minor issue.
One year it was a flat front tire. Not a single person in the pits had a spare 16 inch tube. It's only us Period 3 sidecar guys that use them. A $5.00 item nearly cost me several thousand dollars that I spent to be there. We had arrived on the Friday and it happened to be a public holiday. All the bike shops were shut. Some smart arse yelled out "Yer ridin' a Massey Davidson, try the tractor shop."
And funnily enough, they were open and had 3 in stock.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Originally Posted by RicThompson View Post
I now have a set of NOS S&S 9.5 to 1 forged pistons for my 4 and 5/8 stroker build. Question is do I run as is or polish them?
Just a light deburr/ polish of any sharp edges on the piston tops... the dome and valve pockets. Dont the polish the skirts. Look over the ring grooves and pin bores, lock grooves for anything that needs detailing.
I dont think it’s worth having the pistons tops coated in a 9.5:1 engine, but two pistons is not that big of an expense.
Sleepy LaBeef (July 20, 1935 – December 26, 2019) RIP
With the basically "stock" 900 engines I used to run on pump gas ceramic coating was always done. But running them WOT for fairly long periods on a race track is nothing like running them on the road.
On methanol it just isn't necessary.
On pump gas the engines would never survive no matter what I did to the pistons.
Maxeffort's Avatar
That’s great!
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant futuremrmom9r has a brilliant future
Most of those S&S pistons have a small raised dot about 3/8" in diameter located top center on the crown that is a leftover from TRW's manufacturing process. I don't remember if that set has been done yet , but that dot should be filed smooth.
Otherwise they need nothing but the right clearance which is what they really care about.
And yes carbon is a very good insulator.
Actually that set I purchased from you are very nice. The little raised dot thing does not appear to have been filed down but you can hardly feel it with a finger nail.
I did want to verify with you a couple things I am unsure of. I cannot see much if any difference in valve pockets nor can I see any offset in piston pin. I will put valve relief that is stamped with oversize .040 to the intake unless you tell me otherwise.
