0 BEST LONG CHROME fILTER FOR 2001 EVO sPORTSTER
Last Post: FiftySixer
0 Scorpion battery
0 How to jumpstart a motorcycle
0 Did something silly maybe?
0 Steering stem too short for tapered bearings, convert to balls?
0 Hand brake for rear drum
0 Oh deer
0 04-06 metal oil tank
Last Post: BestCoastXL
0 Can't install pushrod cover
0 6 month old battery discharged and now won't charge at all
Last Post: adri
0 Short in the turn signals, opened it up, brass fell out?
Last Post: Debute23
0 2007 1200 low idle when hot...
Last Post: kuch73
0 Decade Long Project
0 pop's through carb at,idle
0 Coffee serving
0 What makes a Hugger a Hugger?
Last Post: BWP 5p
0 an old Lady
5 Ever Have Days Where You Can't Stand Your Significant Other?
0 Gas Cap problem?
Last Post: ZTatZAU
0 Allegheny National Park III
0 oil light flickering
Last Post: stewart
SoCal 1200N (61), riverar7 (57), rx3732 (48), gnrxl2002 (44)
Old 3rd December 2021
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
Default Aftermarket nose cone module vs aftermarket under seat module
Specifically the Dyna series of modules which is preferred and why. I'm concerned that the Dyna nose cone modules would go bad due to the heat in the nose cone. Is there any difference in longevity between the two. And do they have the same adjustability. I'm learning towards getting an under seat module for this reason
Sent from my LM-G900TM using Tapatalk
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant future
I’ve been thru two nose cone modules from heat.
I run the remote location Dayton twin tec 1007 I believe, under my seat.
Once gets to hot, just a matter of time when timing gets out of whack.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Sportster/Buell Year: 1974
I'm not saying you're wrong about the heat issue. But please elaborate a bit.
Do you have conclusive evidence that the failures were caused from heat? And were the 2 modules that failed the same brand and what brand were they? Approximately what year were they made?
Thanks for any info you can provide.
Edster's Avatar
I have not tried either module. I'm wondering what others have experienced. I know that the factory nose cone modules have had issues. I'm wondering if the same is true for aftermarket nose cone modules.
Sorry, I should have made it clear my questions were for Groovemeisterus. I'm also wondering what others have experienced .
tit for tat
both have the pickup inside the points compartment.
remember, anything electronic is subject to fail not IF but WHEN
that said, i had one ultima fail but the second still kicking. i did push the envelope
now i have a compu-fire install in 1975 with nearly 200k miles and still kicking to 7.5k redline. it has no bells and whistles just the ole mechanical adv.
They were Harley screaming eagle. Bike ran fine when cold. When on long ride in heat, ignition module would start making the engine sound like a sewing machine.
Once engine cooled down, all was better. Would never have thought was ignition cone module, but once replaced it, didn’t have anymore issues. But years later happened again. Changed module again to remote under seat and no more issues.
Then ran across an article later and it basically described what was going on and made since.
Anything electronic can have heat issues to cause issues.
mick42's Avatar
mick42 mick42 is offline
Sportster/Buell Model: 1200Roadster
Other Motorcycle Model: BMW K1600GT
mick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond repute
I’ve been running the same private label version (R&R Cycles) of the Twin Tec 1005 nosecone ignition for about 11 years without any issues and as you can see my D&D pipes run right over the unit so if heat was going to be an issue I would have have seen it by now.
Automotive electronics are a roll of the dice and dodgy grounds are not your ignitions friend.
Life asked death “why do people love me but hate you”,
Death responded, “because you are a beautiful lie and I am a painful truth.”
‘Buddha’
Old 4th December 2021
ignition module failure can occur from other sources. a common over looked area is secondary resistance.
if the coil cannot properly dissipate the the electrical energy through the plug, you can have a high flyback pulse which can eventually short the flyback diode in the module. this also leads to over heated coil.
just changing spark plugs can mask other issues since they fire at a lower voltage level. an ignition o-scope is your friend here.
