0 rear master cylinder
0 New stuff from Harely
0 Range With EFI 2.1 Gal Tank
Last Post: jammantoo
7 Tach Drive Magneto by Burkhardt questions
Last Post: drumbrake
0 Stars and spanners?
0 Who's still riding???
0 Bendix / Zenith questions
Last Post: ezmerf
0 S&S IST Ignition
0 G,Day from Gods Country.
Last Post: Hobes
0 Both of my Sportsters going to the auction now
Last Post: Yellowstone Kelly
0 Fender Fit and Shinko 270 On Rear 4.50x18?
Last Post: drjperformance
0 remap. Y/N?
Last Post: oupa
0 oil plug 1959 xlch
Last Post: 72 Ironhead XLH
7 Starter Problems???
Last Post: maverick31210
0 Question on 2017 forty eight suspension
Last Post: Adam76
0 The O-FISH-ALL Red Sportster Thread
Last Post: Lone Rider
0 Spark Plug
0 1200 after market coils
Last Post: Metalhead86
Last Post: 60weight
0 ***DK Custom-22LR LED Run-Brake-Turn Lights-Universal Fitment***
0 DK Custom Products Streamliner Bullet Turn Signal Relocation Kits
0 Getting a face full.
0 Headlight Modulator
14 Iconic Parts that say it's a Harley!
bore, cylinder, piston, rings, scoring
Old 14th September 2018
T_worth T_worth is offline
Sportster/Buell Model: Xlh 1200
Sportster/Buell Year: 96
T_worth is an unknown quantity at this point
Default Cylinder Bore scoring marks
I just took the cylinders off my 96 sporty 1200 for a top end rebuild. I realized that my jugs are actually Drag Specialties because of the machined "A" symbol on the corner. With inspection of the bore. I'll still measure it with a telescoping gauge and a micrometer, but I don't think i'll hone it since I can still see the honing marks on the cylinder.
But I do notice "scoring" like lines down the length of the cylinder. (reference photo). The lines in the bore are smooth. no nicks or burrs. When it scores down like that, what does that mean?
(Photo:https://ibb.co/nNNvpp)
(Photo: https://ibb.co/cdmH0U)
BKB's Avatar
BKB BKB is offline
Means something got into the cylinder & got between the rings & the wall. If it wasn't using oil & had good compression, it might be okay. Why did you think it needed a top end rebuild? I'm no machinist, just curious & some of the guys on this forum are very knowledgeable & may be able to give you solid advice with more info from you.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
My bike had good compression, but I was burning oil in my rear cylinder. Wasn’t sure if it was worn rings or valve seal. So I decided I’d change both and do a top end rebuild. Also picked up this bike a few months ago, so this is allowing me to be more familiar with my bike.
I’m inexperience with bore knowledge, so some guidance would be appreciated.
BKB's Avatar
BKB BKB is offline
If I were in your shoes, I'd be getting a 1275 kit from Hammer. Not the cheap way out, but you've already got it apart & it probly needs more than just a gasket set to get it back on the road.
