Snippets
View Poll Results: go on green light or anticipate?
anticipate the green light
28 |
70.00% |
launch soon as you see green
5 |
12.50% |
have your own unique technique
7 |
17.50% |
10th October 2009
Posts: 811 Sportster/Buell Year: 2005 Sportster/Buell Model #2: xl883c
stage shallow.. 2nd yellows come on, full throttle, 3rd light comes on and im dumping the clutch..
10th October 2009
Bike Builder
Posts: 1,825 Sportster/Buell Model: xlh1000 Sportster/Buell Year: 1982 Other Motorcycle Model: Triumph Other Motorcycle Year: 196x
well my clutch and shifter are fixed, back to racing this sunday!
10th October 2009
Posts: 15,563 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997
Originally Posted by RacingJake
If your not redlighting during test and tune your not learning how aggressive you can get on the launch.
You should be going on the 3rd amber, if you see green then "Go" you loose.
Deep stage, shallow stage, human delay reacting to the light and the bike's reaction time all adds up. That's what great about test & tune, it lets you fine tune your launching skills
I agree.. if you see Green you're late.. Bracket racing is a combination of ET and Reaction time, many places add your reaction time to your ET to come up with you score..
States I've Ridden in
71.3 hp 70.8 tq
10th October 2009
Posts: 166 Sportster/Buell Model: Sportster 883 Sportster/Buell Year: 2005
Originally Posted by cotnballs
Just remember its easier to red light when you deep stage, with large-diameter front tires, you probably want to deep stage to decrease your rollout on any thing you are racing.
Most tracks require you to designate if you are going deep:
(turning off the 1st bub by rolling past it but leaving the 2nd staging bulb on)
Or by staging shallow:
(only tripping the first staging bulb not going into the 2nd)
the track starter needs to know this info which is relayed from the tower to the starting line or he will not activate the tree till you are fully staged
This info is also relayed to your opponent so they don't sit back waiting for you to fully stage. many tracks are relaxed about this but many more are not. You screw up your opponent if you don't follow the rules.
Just thought I point this out in case someone didn't understand that was reading along.
21st November 2009
Posts: 921 Sportster/Buell Model: 1st EVO - 883 - DEAD Sportster/Buell Year: 1986 Sportster/Buell Model #2: Maybe some day a 1200 Sportster/Buell Year #2: 2001 Other Motorcycle Model: Suzuki Bandit S 1200 Other Motorcycle Year: 1999
Or you go with one of these, along with an air clutch and then your a top bulb guy.
If you want to beat the big dogs you'll need one plus a few other things
Good old nintendo box! Push the button and wait for the ride! Used to do some pit work on Vw that had one. The driver could never get it set up right! I was 15 - 16 then now I think to my self he is a big dummy! Its set it and forget it!
21st November 2009
Posts: 1,535 Sportster/Buell Model: nightster Sportster/Buell Year: 2007
as soon as the yellows light if you drop the clutch the lag time + reaction time should put at the green when it turns .if done right you will cut a perfect light.the quicker your bike reacts the longer you want the yellow on before letting go of the lever.never never wait for the green or you will be blown away off the line every time.period
21st November 2009
Posts: 1,717 Sportster/Buell Model: XLH Sportster/Buell Year: 1992 Other Motorcycle Model: GL1800 Other Motorcycle Year: 2001
Originally Posted by Robotech
You won't pick up any time by getting a better light. The ET clock isn't started until you start moving. You could have a cup of tea after the light turns green and still run a good ET.
I go when I see the last yellow light come on. By the time I see it, recognize it, tell my feet to get moving, and the car begins to react, the light has turned green.
+1.........
2 Weeks Ago
Posts: 3,095 Sportster/Buell Model: XLCH Sportster/Buell Year: 1977
Not... Most certainly Not going to be the same for Any two different folks
If you come to this event,
https://www.v-twinforum.com/attachme...-1-gif.273122/
take part in the school... yea...I know everybody already knows... so No School required..let me say... last year a first timer... and School participant, won the whole Show...
