4 What is the best CCW? Glock? S&W? Sig?
Last Post: 1HD4CJM1X4K
0 Cafe' Image thread WTFN
Last Post: ElHatton
0 Relatively Interesting Road Sign
0 Diagnostic bcm code
0 Suzuki Lights On 883
0 Installing New Tappet Rollers
Last Post: Bruce
0 New member in Pullman Washington
9 1973 XLH1000 stuck front brake caliper
0 Happy Birthday norseXL!!!
0 Cam timing and piston position
Last Post: chevelle
Last Post: dodgetrucken
0 This Mikuni vm38-9 is driving me insane
Last Post: Dave L
0 help with intake manifold dimension
0 Air quality went down the tubes
Last Post: jharback
0 Mid controls on a Custom
Last Post: kaveebee
Last Post: ed_in_az
0 Quick and probably stupid question
0 Let's See Them R's!!
Last Post: Bone
0 Your Favorite Style
Last Post: RKN
0 Mikuni Fuel and Air Metering (possible modifications)
0 Hello everyone!
Last Post: jtnelson89
Last Post: RandyMac
0 What are some sellers thinking?
Last Post: OCRyder
0 WTF Happened
xlhrick (73), madrat (67), gripdad (64), ask4dug (62), TinMan_4L (57), jrhayden (56), norseXL (53), ftcara (52), rick600, thebisch (48), wademclean, smooth8423 (43), timmaboy (42), mxmike800 (28), OddOneOut (27)
Old 15th October 2018
Select by:
Resistor/non-resistor
Thread size
Reach
Heat range
My personal preference is for Autolite. Some useful links from Autolite:
http://www.autolite.com/technical-re...ech-specs.aspx
http://www.autolite.com/productfinder
If you want to do something, you’ll find a way. If you don’t, you’ll find an excuse.
Old 16th October 2018
and clocking them helps if you're the wide open throttle type guy.
indexing helps with starting a kick start bike.especially with a magneto.
Nate.evans Nate.evans is offline
Sportster/Buell Year: 1973
Nate.evans is an unknown quantity at this point
Ended up putting in the H10C plugs in just because it dieseled today....oddly enough, the plugs that were in there , J12YC didn’t look bad
But, I put in the new Champions and it’s like the bike woke up! Throttle is smoother, deceleration is smoother and less popping, all around better.
doodah man's Avatar
i'm looking at the plug on the right, and it appears that where the color changes on the strap that you possibly have too much timing... it's an odd angle for me in the pic - could be I’m just seeing some carbon build up after the 90° bend in the strap; you have the plugs in your hands you'll make a better judge of it...
http://www.4secondsflat.com/Spark_plug_reading.html
The dieseling doesn't look like it was caused by the plug itself.
Maybe it was running so well (making better power) it heated up the carbon deposits!
The ground strap would be blue and the heat would extend farther up the threads than just 2 threads, if it was the plug.
wedge's Avatar
wedge wedge is offline
Totally agree, and this picture doesn't show down inside the plugs at all, however; the gray ring around the porcelain is saying the plugs are staying too cold for this engine.
I wouldn't judge them without knowing more about the engine condition, because the gray could be caused by slight oil consumption.
Are there any black pepper flakes on the porcelain that we don't see?
What your pictures should actually be showing us is down inside the plug. I like to place the plugs side by side on white paper, then touch the hex and the tips together so they angle towards each other on the tip end. If you can manage good lighting inside the plugs you can take a picture that shows down into both in the same shot.
