4 What is the best CCW? Glock? S&W? Sig?
Last Post: 1HD4CJM1X4K
0 Cafe' Image thread WTFN
Last Post: ElHatton
0 Relatively Interesting Road Sign
0 Diagnostic bcm code
0 Suzuki Lights On 883
0 Installing New Tappet Rollers
Last Post: Bruce
0 New member in Pullman Washington
9 1973 XLH1000 stuck front brake caliper
0 Happy Birthday norseXL!!!
0 Cam timing and piston position
Last Post: chevelle
Last Post: dodgetrucken
0 This Mikuni vm38-9 is driving me insane
Last Post: Dave L
0 help with intake manifold dimension
0 Air quality went down the tubes
Last Post: jharback
0 Mid controls on a Custom
Last Post: kaveebee
Last Post: ed_in_az
0 Quick and probably stupid question
0 Let's See Them R's!!
Last Post: Bone
0 Your Favorite Style
Last Post: RKN
0 Mikuni Fuel and Air Metering (possible modifications)
0 Hello everyone!
Last Post: jtnelson89
Last Post: RandyMac
0 What are some sellers thinking?
Last Post: OCRyder
0 WTF Happened
xlhrick (73), madrat (67), gripdad (64), ask4dug (62), TinMan_4L (57), jrhayden (56), norseXL (53), ftcara (52), rick600, thebisch (48), wademclean, smooth8423 (43), timmaboy (42), mxmike800 (28), OddOneOut (27)
Old 1 Day Ago
Sportster/Buell Year: '59
Other Motorcycle Model: 2004 XL883 '57 Tribute
PetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud of
How is there clearance to allow the spacer to not fit square? I don't see how that can happen. Drop, sure. But then there are the bearing adapters sold to allow you to use the stock bearings, with a smaller axle. Wouldn't the same thing happen if it was possible in the first place?
Pete's Ponies Mustang RUSToration & Performance
Old 1 Day Ago
TonyGall TonyGall is offline
TonyGall is an unknown quantity at this point
when I said square I ment the peripheries of the spacer wouldn't line up with the inner bearing race if it drops. it would probably be ok but you asked the question what should you do, if you are replacing the bearings why wouldn't you replace the spacer for the correct size ?
