0 Arbor press for crankshaft
Last Post: thefrenchowl
Last Post: halfmt1
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
0 It's Flame__'s Birthday!
Last Post: Skwerly
Last Post: Skwerly
0 compression problems
0 Motorcycle Events
Last Post: rhartlin
0 Wanted: Sportster mid controls
Last Post: Texassporty06
0 my build in my apartment
0 Finding a new doctor...
Last Post: oupa
Last Post: oupa
10 Exhaust Pic thread
0 ultima iggy,, static time vs dynamic time
0 Piston Scuffing
Last Post: tattooglisha
0 A thank you
0 Flat Tire
Last Post: denguy
0 Forum problems???
0 stress killer
0 XT 1250 Ulysses with XR1200 heads
Last Post: Randy_rots
Last Post: toe
0 Little Bunny Foo Foo
Last Post: slcharger
Old 7th December 2018
rocketmangb's Avatar
04-06 has known issues with the rear master cylinder !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
1HD4CJM1X4K 1HD4CJM1X4K is offline
Sportster/Buell Model: XL883C
1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future1HD4CJM1X4K has a brilliant future
If I order a new M/C will the known issue resolve itself?
Is there an aftermarket Master Cylinder anyone would recommend as a good replacement upgrade?
Believe the internet when it confirms your preconceived notions."Abe Lincoln"
Originally Posted by farmall View Post
I
It took about five minutes leisurely searching to order the last rear master I bought. Find part number using Ronnie's site,
$74.49 is not a bad price for peace of mind.
Wonder if the 2007 version is the same, or is it improved, without the known issues.
Will it work on a 2004 or is it a departure in design?
Just want to move forward without worrying about future problems.
harley506d's Avatar
Sportster/Buell Model: 1200c
According to Ronnies, the '05 and '06 use the same part 42521-04
I think the 07 master is designed for DOT 4 fluid but I am not sure
Surdyke HD
http://www.surdyke.com/Search.aspx
throttle stop works wonders also.
brakes are a science nowdays. the old 74ch rear drum sucked but changing shoe material helped greatly at reduce drum life. the front sucked a little less but same thing, going to more aggressive pad at same cost, only bad thing is it does add to torque steer on hard braking. my 01 sport with dual fronts works nicely.
but remember one thing, a locked wheel has zero steering.
Followed the link:
No items found
Will reseach..
Thank you!
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I go through one rear master cylinder a year so no they are not improved. Keep in mind I am putting 20-25,000 miles a year on my bike most years. I'm also on my 3rd rear caliper after 240,000 miles
2007 they did switch to Dot 4 fluid, not sure what changes other than those to possibly accommodate the different fluid were made
John Wayne - "The Shootist"
hbsporty's Avatar
hbsporty hbsporty is offline
Sportster/Buell Model: 883c>1250cc
Other Motorcycle Model: 2002 FLH Standard
hbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud of
I also have had issues with it. I got a new cylinder and rebuild the old. My problem always happened when I changed the rear tire. I happened on to a you tube vid on rear breaks. I don`t know how to give the link so here is what to look for on you tube. Rear Break Caliper Alignment - fix rear break. It is by Phil Chapman. Before I did this the piston moved but you could see that the pads were not touching the disc correctly. Be careful not to remove the bolt all the way. I used a dumbbell to hold the peddle down. After this I could see the pads hit correctly and had better rear breaks. To bleed the breaks I use a Miny Vac which pulls the fluid out the bleeder. Good luck and if anyone can help with the link to you tube or the Miny Vac chime in.
