0 Dragging clutch
Last Post: Ark OB
0 Starter Relay?
Last Post: andy2175m4
0 Oil pressure switch
0 Q cams in 73 xlh ??
0 Carb ???
0 Video - FEED THE BEAST - Your Harley Will LOVE This Mod!
0 Deeded Electrical
0 It's Glamazon's Birthday!
0 need help with 68 XLH
  #31
Old 11th July 2018
ParrotHead's Avatar
Other Motorcycle Year: 1974
Originally Posted by XL Ed View Post
Hey D0c. I am in the process of wiring in those lights we talked about earlier and a cell phone charger. Is there an easy way to hook them to a keyed power source rather than direct to the battery?
Most of the wires likely could not handle the load of the lights so you probably would need to use a relay. The stock HD aux lights use the low beam wire as the keyed source to trip the relay. For charging the cell phone I simply use a USB connector that plugs into my heated gear plug (always on). As a backup, I have a USB adapter to plug into my battery tender cable
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
