0 Dragging clutch
Last Post: Ark OB
0 Starter Relay?
Last Post: andy2175m4
0 Oil pressure switch
0 Q cams in 73 xlh ??
0 Carb ???
0 Video - FEED THE BEAST - Your Harley Will LOVE This Mod!
0 Deeded Electrical
0 It's Glamazon's Birthday!
0 need help with 68 XLH
  #111
Old 11th July 2018
ParrotHead's Avatar
Other Motorcycle Year: 1974
Originally Posted by XL Ed View Post
Hey D0c. I am in the process of wiring in those lights we talked about earlier and a cell phone charger. Is there an easy way to hook them to a keyed power source rather than direct to the battery?
Most of the wires likely could not handle the load of the lights so you probably would need to use a relay. The stock HD aux lights use the low beam wire as the keyed source to trip the relay. For charging the cell phone I simply use a USB connector that plugs into my heated gear plug (always on). As a backup, I have a USB adapter to plug into my battery tender cable
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Old 11th July 2018
60Gunner's Avatar
60Gunner 60Gunner is offline
Yep, near the fuse block under the seat. Should be a gray accessory plug for an accessory adaptor kit.
Either above or in front of the battery. I believe in front. I'm not home to look.
Old 11th July 2018
ParrotHead's Avatar
If that is what is referred to as the B+ connector it is always powered. That is the source of power for my aux lights, but there is a relay that is tripped by a tap off the low beam wire. On my 06 it was under the seat
Old 11th July 2018
60Gunner's Avatar
I'm not using it but I understood it to be keyed. I saw it when i plugged the race tuner into my ICM and wondered what it was.
My bad. Must've read it wrong or just assumed it was.
Old 12th July 2018
ParrotHead's Avatar
I thought it was and used it to power my GPS. Imagine my surprise when the GPS stayed on after the bike was shut off. Then I remembered the relay that I installed for the lights. I had thought that was to turn the lights off when the highbeams were on but I guess it was to turn the lights on when ignition was on.
Maybe they changed it in more recent models
Old 12th July 2018
The B+ connector is intended for the Battery Tender - it connects to the Battery thru the Battery or P&A fuse (depends on year) - NOT thru the Keyswitch - It's always ON...
2 Relax
Old 7th October 2019
I AM GRUNT's Avatar
I AM GRUNT I AM GRUNT is offline
Sportster/Buell Model: Sportster 48
Sportster/Buell Year: 2019
I AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to behold
Anyone know how I can identify the RHCM harness connector inside the left caddy panel on a 2019 Sportster 48 without tracing the wires, lifting the tank and seat ? Mine sh*t the bed over the weekend and want to know where I should begin my diag. Any insight would help !
Sincerely, The Grunt | 2019 Sportster XL1200X
sportsterdoc's Avatar
Might have been best to start a new thread, but I can dig out my laptop tomorrow to access schematics.
Explain "identify". Do you want to know wire colors?
ParrotHead's Avatar
Dumb question, but if you have a 2019 Sportster why not have it fixed under warranty?
That was suggested in another thread he joined
