0 Track Bike Build
0 Q cams in 73 xlh ??
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 5th November 2019
What's that go on bustert?
I'm still a little fuzzy on timed breathers.
Before the new umbrellas, I lost 3-3/4" (7-1/2" WC) and the engine died when removing the oil cap.
I checked today and I still lost 2-1/4" (4-1/2" WC) when removing the cap.
But, I only lost a slight pitch in the engine and not a noticeable amount on the tach.
No frothing in the oil tank now with the cap removed at idle.
So it does look like the rear umbrella was on the way out.
I had (previous to any testing) set the A/F mixture by the Idle Drop Method:
http://www.sportsterpedia.com/doku.p...rop_method_idm
Today I moved the mix to and fro and found no difference on the slack tube.
edit:
I tried to get to 6000 while testing in the shop and it won't do it.
But on the road, easy peasy.
Do I need to go back into the carb?
Last edited by Hippysmack; 8th November 2019 at 02:04.. Reason: moved pic to Sportsterpedia
