0 why you can't be seen
0 need help with 68 XLH
Last Post: mrmom9r
0 Oil pressure switch
Last Post: Edster
Last Post: Fivecats
0 Q cams in 73 xlh ??
0 HSR idle mixture screw
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
0 Gear and brake linkage
0 oil to front rocker, no oil to rear?
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
0 78 Ironhead switchgear parts
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Old 5th August 2021
zukinut zukinut is offline
zukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud ofzukinut has much to be proud of
Default Fork question
What is the difference between forks from 04-21 and 88-03? Was talking to legend about their cartridges and they have two available options for my 01. A +2 and a stock height. HOWEVER, if I had an 04 I could only use the +2.
I’ve got an 883c and I’m gonna run a 13” rear shock. Jus wanna make sure I do the correct cartridge so that my rake/trail stay correct and I get the best ride possible.
Thanks again for all the help.
Will
