Last Post: jeffro57
Last Post: DR DICK
0 Indicators not flashing
Last Post: steve-o-
0 1975 Sportster
Last Post: bplinson
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: lehel
Last Post: jibber
Last Post: Gulf Coaster
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
0 Starter Relay?
Last Post: Akdawg
Last Post: mac93
0 Q cams in 73 xlh ??
Last Post: 73HEAD
  #31
Old 8th August 2021
canoli's Avatar
canoli canoli is offline
What is the original issue that led to you testing the units? Repeatable noisy tappet?
The pushrod seals were leaking and while replacing them I pulled out the lifters. They were fine except the front exhaust, which was sticking in its cylinder. I cleaned it really well but it's still sticky and I don't want to run the motor till I get a good lifter in there.
There are no set screws in the oil passages - doesn't appear it's ever been running solids. These blocks don't have the oil fitting and the short hose going to the jugs (Harley tried that for a few years after 1981 I think). I can see oil coming through the passages on both cylinders so I guess the tappet block gaskets are installed correctly.
I don't want second guess the FSM. I would like to understand the reasoning better though.
I didn't really doubt Petersen but it's good to see the same test in the FSM. Why these 2 lifters failed it ... I think I can rule out user error. Maybe I'll pull a good one from the motor and see how it does with this "air test." If it fails then I know I'm doing something wrong I guess.
Old 8th August 2021
That sounds like a good direction.
Old 8th August 2021
canoli's Avatar
Thanks HS I was hoping somebody would second the notion.
Old 12th August 2021
canoli's Avatar
Final verdict - I got sold 2 bad lifters...
The working lifters I pulled from the bike all passed the "air test" without issue. One was a little less tight than the other 2 - didn't pop up quite as high - but all 3 held for a 10-count and popped back up more than enough to show the seal (check ball, whatever it is exactly) is working.
The 2 bad ones I bought - 1 Sifton and 1 Drag Specialties - they're not by any chance the same company are they?
