5 How do I increase sag ?
Last Post: andy2175m4
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Q cams in 73 xlh ??
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 27th August 2021
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: XL883 w Hammer 1275
Default 1275 Dyno Chart Reference: All 883 -1275, all 1200 - 1275 conversions
For all 1275 dyno sheets. This is for dyno sheets only, no comments they will be deleted. Thanks
XLF Rules/Guidelines
XLF Guidelines II
Hammer Performance 1275 kit w flat tops, 2007 1200 heads with Hammer Impact Service, Hammer Performance custom billet intake manifold, Stock carb, N65C needle w 45/185 jets, K&N air cleaner, SE 497 Cams, Energy One clutch w 15% spring, Python 3 Slip ons, Dynatek DSPT-1 ignition on 28b
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
I'll kick this off with a chart especially for you Michele
This is a chart a customer posted on FB a few days ago.
  • 2006 XL1200C
  • 1275 kit
  • IMPACT head porting
  • HP560 cams
  • TC88A ignition
  • HSR 42 carb on a ported stock manifold
  • V&H Side Shots, baffles cut in half
  • S&S air cleaner
Blue is before tuning, red is after.
I'm sure you see the resemblance to a certain "other" build ...
Click Here to Contact Me
Old 29th August 2021
yelladox yelladox is offline
Sportster/Buell Model: xl1200ns
Sportster/Buell Year: 2018
yelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant future
Here is mine!
2018 Iron 1200 to 1275
Interestingly, although I have the 570 cam, my party only really starts at 4k RPM. I tell people I have a 90/90 setup.
  • Dynojet powervision
  • Bassani Road Rage 3
  • DK Custom HiFlow 606 Air Cleaner
  • Drag Specialties external breather
  • 1275 kit
  • Flat top pistons
  • Jackhammer 570 cams
(bronze oil gear, S&S precision lifters)
