0 It's Glamazon's Birthday!
0 Track Bike Build
0 Q cams in 73 xlh ??
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
Old 20th August 2021
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Looking good so far, and the wood work is great.
Blue belt in Serious tea drinking. :)
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Thanks all, it will keep me busy all winter that's for sure.
I retired from my "career job" in 2015 but have been doing the MC repair from 2013 on.
Got way too busy so had to cut back. Still have a handful of customers, mostly the folks I ride with.
BTW I do have a F-Head Willys engine to rebuild and install if I ever want to go back to near stock.
The 259 was in it when I bought it.
Old 30th August 2021
ParrotHead's Avatar
Other Motorcycle Year: 1974
Originally Posted by decman View Post
Thanks Chris!
I'm always open to friends and travelers.
Just needed to trim a lot the excess crap I was doing.
You don't know how close you came to having me back again in June. I had the same brake issue as I entered WY on my way out to the IBR in June. I opted to continue on to SLC and bleed them first which worked for about a week or so. Then whenever it got hot they started fading but was able to pump them up.
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Crusty Crusty is online now
Sportster/Buell Year: 2016
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XL 1200 R
Any news or updates for those of us who are quietly following?
Post no Avatars!
Yea, sorry, last 2 months have been busy/weird for me.
Wasn't feeling so great (non covid related) and had to take care of some things.
Even missed BMST at Bonneville this year because of it.
Anywho, I have the rear end just about finished. Changed bearings and seals
in the Timken clamshell rear end. That included a lot of machining by me of parts no longer available.
Timken made differentials for a lot of trucks back then. Spicer (now Dana) made the rest.
Had to make some shims and even some bronze bushings for the rear leaf shackles.
Painted the frame with Eastwood Black Rust Encapsulator, nice stuff looks great.
Yesterday I got the new rims and tires in, so I need to mount them up and get some pictures to post.
Give me a day or two.
Thanks Declan, we will try to be a little more patient
I.B.A.#26543,
Post no Avatars!
Well here are some more pics.
First is the rear leaf shackle with bushings, one bushing I made by turning down a shoulder bushing, the other was a stock size from ACE hardware.
My rebuilt Spicer T-18 transfer case.
rear frame painted and new brakes and drums. Replaces seals and some bearings in the Timken clamshell differential.
New rims and tires, new lug nuts and center caps on the way.
A seat I found locally, from the back of a side by side. It was cheap and the right width.
Can't see the pictures...
It's sometimes difficult to get Google Images to post correctly - When I tried using the link directly, Google wanted a login...
For Sportster Tech Info:
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Other Motorcycle Model: FLHRI
I don’t even see links unless I quote his message.
“Smooth roads, Blue skies and Green lights”
ChinCactus's Avatar
Funny, I see them fine. Impressive work.
