Last Post: Fivecats
0 What oil temp do you run
0 HSR idle mixture screw
0 Oil pressure switch
0 Gear and brake linkage
Last Post: The Doctor71
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
Old 10th December 2012
1nastydc2 1nastydc2 is offline
Sportster/Buell Model: 72 xlch basket case....
Sportster/Buell Year: ....
1nastydc2 will become famous soon enough1nastydc2 will become famous soon enough1nastydc2 will become famous soon enough1nastydc2 will become famous soon enough1nastydc2 will become famous soon enough1nastydc2 will become famous soon enough
nice build so far cant wait to see the end.
Old 11th December 2012
thor0812 thor0812 is offline
thor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to allthor0812 is a name known to all
Got some more done tonight. None of the pieces are tacked in yet. Just getting a feel for it
In case you haven't noticed in the background here is the front and the tank
geoff 1's Avatar
geoff 1 geoff 1 is offline
Sportster/Buell Model: sportster 1200r
geoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud ofgeoff 1 has much to be proud of
This looks like its going to be a lovely scoot,Thats a fairly radical frame in the making!
2007 XL1200r; 560 cams, power vision, Hagon nitro shocks.
2001 XL883, in a hardtail frame.
Old 12th December 2012
Didn't get a whole lot accomplished tonight. after aligning, taking apart, realigning, checking and rechecking I tacked int he down tube. Checked again and finally welded it in. Hopefully I can get the lower frame rails fit up and welded tomorrow then start on the rear motor mount.
mullemeck's Avatar
mullemeck mullemeck is offline
Sportster/Buell Model: xl1200
Sportster/Buell Year: -93
mullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nice
Nice welds! I Can see that you are a pro :-)
It will be fun to chop this one
Old 13th December 2012
Thanks, no fancy dancy machine either. Old Miller AC/DC Thunderbolt and a scratch start air cooled tig.
Got quite a bit taken care of this evening. Got the rear motor mount and seat post in. Figured since I had gone that for might as well go ahead and get the back bone in place. Starting to look a little like a motorcycle again!
Also got the two bottom rails tied in to the down tube and cleaned up.
Old 14th December 2012
1200xlman 1200xlman is offline
1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough1200xlman is a jewel in the rough
So I been wanting to do something like this but unsure how to or what to do about the vin number
Vin is still stamped into the neck. Just have to be careful when working in that area to keep it intact and readable. As far as how to do it, just gotta do it! If you have any questions just pm me
Old 16th December 2012
Been busy the past couple of days. I got the rear end all tied in. Happy I was able to keep the backbone and upper legs on the tail section at the same angle. Everything just seems to flow better that way to me. Got about 90% of the welding done, everything I could get to on the fixture. Got most all of the plug welds done and started the smoothing process. Gonna finish up the few little spots and plug welds tomorrow. Super stoked to get it off the fixture and see it standing on its own. Sat the tank up on the backbone to get an idea of how it will flow with the rest of the bike.
Doodle Doodle is offline
Sportster/Buell Model: Xl883C
Doodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of lightDoodle is a glorious beacon of light
Looking good. You gonna brace the neck or leave it open?
