Last Post: Deimus
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Track Bike Build
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 8th November 2020
The Sportsterpedia is always evolving - Sometimes, that means re-organizing the information...
If the reference was to the CKP, it here now:
http://sportsterpedia.com/doku.php/t...shaft_position
sportsterdoc's Avatar
Thank you
Second link in post 20 updated.
