0 Deeded Electrical
0 New to the boards here and wanted to say hi!
Last Post: SophieWillow
Last Post: maltesefalcon
0 Carb ???
0 It's Glamazon's Birthday!
0 Dragging clutch
Last Post: Ark OB
0 What oil temp do you run
0 need help with 68 XLH
Last Post: andy2175m4
0 Mainshaft Oil Seal Leak
Last Post: mac93
0 For Sale 2003 XL883C 1200 Conversion
Last Post: webrehm
Last Post: Fivecats
Old 1st June 2017
waza's Avatar
waza waza is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: 1978 FLH Shovelhead
waza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nice
I just went thru the same thing. I was taught to replace gears in sets, so I was going to get 2nd & 3rd gears but noticed my 1st gear set was a Taiwan Ted or some other crap, so I threw in a set of 1st also. Then I started thinking about that big 4th gear jump with my 22/48 gearing so I figured I might as well change it now. So, I ended up ordering a W first gear set & a C 4th gear set & got all gears for a little over $600. Replaced the bearings & 1 shifter fork. I think I have about 650 in it now.
As of this past weekend it's together and all I have to say about the NEW gear ratio is HD should have done this a long time ago
Is there anyone that sells a "set" of end shims for this? Ordering one at a time is a P.I.T.A.
Good luck on yours!
Old 2nd June 2017
Smerch's Avatar
Smerch Smerch is offline
Smerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to behold
Waz-
I did the same thing this winter, C box with a wide first (22/49).
Seems like a whole 'nother motorcycle. Makes for a much better ride on the back roads.
As far as the mainshaft R/S thrust washers, search for "DS-194183". Several places sell them, 15 pc. set from .030" to .125" for ~$40.
Old 2nd June 2017
waza's Avatar
Originally Posted by Smerch View Post
Waz-
Thank you MUCHO!!
Old 3rd June 2017
jdearmitt jdearmitt is offline
jdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura aboutjdearmitt has a spectacular aura about
Thanks everyone for the info and leads on parts! I did drop the trans assembly off Thursday at a local shop that specializes in old Harley's to get his evaluation on what I have going on. I will update when I get a diagnose back!
Thanks again!
Old 3rd June 2017
doodah man's Avatar
what's the name of the shop, and where are they located - if they truly are good, we have a "recommended indy shop list" in the sticky section, maybe they could be added if they're not already in there...
Old 4th June 2017
R&J Cycle 123 Motor Sport Ln, Ford City, PA 16226
I was recommended to Ross through a series of people so this will be my first experience and I will report back if it is a good one. I believe it will be judging from his "40 years" of Harley experience and his general great demeanor on the phone and in person when I dropped the trans off. Excited to hear my results so I can enjoy riding my Ironhead this summer rather than just wrenching on it
Old 4th June 2017
doodah man's Avatar
Originally Posted by jdearmitt View Post
...Excited to hear my results so I can enjoy riding my Ironhead this summer rather than just wrenching on it
Enjoy the wrenching also, though, when it becomes necessary rather than looking at it like a chore. There's no such thing as a maintenance free ironhead!
Old 4th June 2017
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
Are you gonna set the main shaft and counter shaft end play,can't figure out how he's gonna do it without your motor.
Murphy's Law :vvet:
Old 4th June 2017
Yeah we are starting with figuring out what the trans needs and going from there. Either I will set the end play or take the rest of the bike to him to finish the set up depending on price.
Thanks!
Old 9th January 2019
falotz2 falotz2 is offline
Sportster/Buell Year: 1982
falotz2 is an unknown quantity at this point
I have the same bike and had a copper washer fall out when I took the primary off and cant find for the life of me where it goes.....Any ideas? Shifter Shaft? Everyone says starter shaft but the shaft doesnt hang out far enough to put it......Any help would be greatly appreciated.
