0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
  #281
Old 27th July 2019
dieselvette's Avatar
List price for a pair of stock umbrellas is $24. So if a person is poor and trying to fix breather problem, thats a good place to start.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 27th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
I wasn't going to waste any money on something I know is adequate at best and have to do it again 3 years from now if I'm lucky. Especially given I'd be pulling the rocker covers again too.
Just shot boiling water at 216° holding it 4 inches away just like the oil. I'm satisfied my temps are more than good.
Old 27th July 2019
Hippysmack's Avatar
Head temp and oil temp are 2 different things Hippy. Head temps are always higher. 320 is actually low for head temp after a hard pull.
I know.
But oil is also a coolant.
If it fails temps go up also.
Thinking out loud again.
I checked mine and I'm at an average 270-280F about an inch away.
Oil temp 194.1F
4 grand for 5 miles.
Haven't read anything on head temps yet.
Don't know if that's good or bad.
Old 27th July 2019
60Gunner's Avatar
I know.
Oil temp 194.1F
Mine was right around there except by the exhaust port. Even that just flashed 322 briefly then right back below 300. I may have pointed it closer to the pipe. I was moving it around looking for the hottest spot.
Otherwise I couldn't even find 290.
My oil temp at the tank was a steady 190. I just verified the accuracy of that.
I'll redo the head and shoot the other side closer to the combustion chamber but away from the exhaust where the temp sensor is on newer bikes and reading closer to 380.
Old 27th July 2019
Hippysmack's Avatar
Originally Posted by Tomcatt View Post
It may pump a little less but it's still a positive displacement pump and the point I was making still stands. Adding two piston squirters doesn't increase oil flow into the engine. In simple terms the squirters just steal a little flow that would have gone elsewhere but the total is still the same.
Look at it this way.You have a positive displacement pump pumping pumping 20 gal per minute at 3,000 shaft rpm. Just an example. you can have 5 outlets delivering 4 gal per minute or 4 delivering 5 gal per minute, the pump doesn't care it just mindlessly pumps 20 gal per minute.
I understand.
I guess I should've clarified.
I don't feel like oil gathers as quickly in the sump on rigids as they do on rubbermounts due to their oil squirters.
The pump delivers what it's capable of.
But I wonder, if once the restricted paths in the feed line are inline with the feed system and the pressure builds due to the restrictions, at what pressure could the pump backfeed (lowering static, basically it's own pressure relief back to the inlet side of the pump due to wear).
Originally Posted by dieselvette View Post
The differences are barely perceivable, so for your average Joe this test is too subjective.
That's interesting.
I guess I didn't think about when they get stiffer, the don't open as well.
Even if they do seal on backflow, they could still raise pressure on downstroke.
+1
Hippy seems to be interested in oil expulsion. Here is a picture of the foam. You can kinda see how it's layered from top-to-bottom from more dense, to less dense.
(As-installed the less-dense would be toward the umbrella).
Also worth a look is the orange seal - not sure how this could possibly fail, but if it did that would bypass the "anti-reverse" valve.
Edit: I suppose the plastic housing at the orange seal could become warped, thereby compromising the seal.
Thanks for the pic.
Yeah I can see the heat warping the plastic.
That would bypass the valve somewhat, not sure how much.
The air will take it's easiest route unless it get's restrictive.
I'm not a fan of the mesh.
Did you find a hole, even tiny, between the orange rubber and the opening for the mesh?
I can't see one in your pic either.
Old 28th July 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Oil temp 194.1F
Take a good look at you measuring method. The temps you're seeing are actually low vs the usual norms. Oil in the tank you want to be 220-230F. Over 260F and you should be considering an oil cooler or working on your engine management, tuning. Head temps will be all over depending on where/how you measure. The exhaust port is hottest and the OE sender is really in a good spot. A "gun" won't give the same reading as the OE sender. No way you can "see" that area.
For oil temp a meat thermometer works pretty good if you lean the bike to the right so you can get it down in the oil enough.
The "guns" are great if you want to know your tire temps but not so good for oil or head temps.
Old 28th July 2019
60Gunner's Avatar
Shot by the spark plug on both cylinders. 321/326. Oil at the tank 195.
8 miles at 4000rpm. Took an exit and idled.
I agree with Tomcat. These numbers are probably 30° at least low by this method of taking it. Especially the head temps.
But shooting the same way in the same location on the heads should alert us to any changes in the future. Use these as a baseline.
Actually mine's probably pretty close as I was slowed down then parking and idling. Probably a minute had gone by and cooled off a little? The 380 temps by those with sensors are temps taken while riding at higher rpm with a sensor inside the head.
I shot the same area by the plugs on both heads several times for consistency.
Old 28th July 2019
Hippysmack's Avatar
Yeah I've read the concerns with the oil temp dipstick being off.
I used the infrared in the tank to read 194 then 194.1F
I popped the oil temp dipstick off the tank at 190F
So that was two different measurements in the tank.
270-280F too low?
I got 290 or so near the exhaust but I was concentrating between the fins.
I know I can advance the timing and increase the heat.
I have no dialback light and have been tuning by ear.
She's got game I must say.
I gotsta figure a way to stop squealing tires on takeoff.
I am near bald now.
But I've never heard of timing by heat.
So that may just be my timing setting at the moment.
Old 28th July 2019
60Gunner's Avatar
Yeah, they drops in a hurry. Just the half mile off ramp I took cooled me down. I shot an inch from the plugs on the intake side of them. About as close as we can get to the sensor location.
I know my temps are more than good and if I take them this way all the time now I'll know if I have a problem.
Oil temps should be around 220-230. Even 250 is ok. But by the time I took the temp in the tank, it really had cooled I'm sure. 170 5 blocks later at home.
Old 28th July 2019
But I could put a KrankVent in my existing breather hose without having to get into the rocker boxes with is a big PITA. If you're not doing this yourself and paying someone, just adding a KrankVent would have to be a great deal relatively speaking.
It's not that big of job, but you are right if you're paying someone to maintain the bike then the krankvent is a good value (assuming it will last for 50,000 miles, because it's not cheap).
But, it wouldn't bother me a bit to swap umbrellas once a year on some wintery day. STILL not trying to defend the stock valves, I'm just saying it's not a deciding factor for me.
