0 Gear and brake linkage
Last Post: 93trident
0 What oil temp do you run
Last Post: The Doctor71
Last Post: Hardtail28
Last Post: mrmom9r
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
Last Post: Fivecats
  #761
Old 22nd August 2019
Hippysmack's Avatar
Everyone actually didn't just run the same jets, the same jets were drilled to taste in many cases.
That's how I used to do Quadrajets.
I found a Hayden vent opened up. That's a very tight fitting little umbrella chamber!
It appears the PO installed this inline on the tank vent.... on an ironhead
Originally Posted by leucadiaGuit View Post
60Gunner's Avatar
60Gunner 60Gunner is offline
It is. And the umbrella fits tight where it pushes in too. That why I didn't think it was using the same umbrella. Just seems so much sturdier.
Would that work in the fuel vent line? They do say not to clean the umbrellas with fuel.
i was talking about extra time. tooo old to wrench the machine anymore.
i run a custom jet in my sport. you can silver solder them shut and then drill to size, do not forget the chamfer.
on the ole ch and mikuni vm, i even polished the needle down.
hobby lathes come in handy.
Hippysmack's Avatar
I don't think that'd be a good idea on the fuel tank.
I should've specified the PO installed it in the oil tank vent line.
which of course is also a bad idea, ( especially inline)
edit:
This was on a 73 XLCH with the timed breather tube.
It seems they were trying to relieve tank pressure by installing an inline vent (positioned one way out the cam chest).
The removal of the path from the tank back to the cam chest seemed to pressurize the tank and blow air/oil out the cap.
oil air vapor
Although there is more we don't know....
Seems like some plumbing issues also.
60Gunner's Avatar
Yes it is.
I'll probably work on separating the oil inside a little better this off season even tho the amount of oil mixing with the vapors is minimal. Maybe even inevitable. Always trying to make things better tho.
Old 23rd August 2019
60Gunner's Avatar
XLF member Rubine went to great lengths to move the scavenging from the rear of the sump to the front of the sump by way of manipulating flywheel force on the oil's direction.
Apparently he believes the wheels play a big part in pushing oil for scavenging.
http://sportsterpedia.com/doku.php/techtalk:refil05g
What was the final verdict on this? Anything definitive one way or the other? Always looking to take a proactive approach to making improvements. Especially in questionable areas like crankcase pressure and oiling.
Hippysmack's Avatar
The thread ended there. I'd like to see a video of this bike running.
Lots of interest in it myself.
60Gunner's Avatar
It's an interesting concept.
60Gunner's Avatar
tooooo bad, tooooo bad, you do not have a trap door
the speedo is history when dropping out of 3rd.
What do you mean the speedo is history dropping out of 3rd?
Old 24th August 2019
http://www.twistgear.net/page%20html/sportgear.html
a real hoot and surprises some rice to boot
