0 1982 rubber oil hoses
0 Gear indicator missing
Last Post: Shahyaan
0 Indicators not flashing
Last Post: Porkchop9
Last Post: fafcpa
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
0 75 XLH Bendix Carb Spitting Gas - Video
Last Post: jibber
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
  #801
Old 3rd November 2019
Hippysmack's Avatar
Iree can you elaborate on that?
The only gas law I know is buy low and ride high.
60Gunner's Avatar
60Gunner 60Gunner is offline
Cylinders going up while others are going down in a car engine. 2 going up and down at nearly same time in a v-twin.
Hippysmack's Avatar
I'd think it would be the high rev swing-ability of Sportster pressure that the spring and diaphragm can't keep up with.
I don't know for sure but yeah, the pressure should be more stable in car motors.
I changed the breathers today and found that a fiber washer on the front box was toast.
The middle broke out, got soft and bunched up around the hole and it now looked more like a smaller thicker washer.
The small piece feels much softer than the easily breakable fiber washer that I installed.
Maybe it bunched up into the hole. There was no oil around the bolt from the outside.
These have been re-used several times before, replaced them all today.
The umbrellas looked good to me.
The front was more soft than the rear but both were still flimsy.
It turns out I only replaced the front the last time I was in there, it had 'James' written on it and the other didn't.
But I replaced them both today anyway.
rocketmangb's Avatar
Update the bolts and washers to the '08 and up style I think
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Hippysmack's Avatar
What's the difference?
2486 and 6589A
Hippysmack's Avatar
What if I just toss the fiber and use the copper?
Can't find a pic of the newer style bolts at the moment.
Hippysmack's Avatar
I'll look them up.
Thanks for the PNs.
Washer is called a Stat O Seal
Hippysmack's Avatar
Aaaaahhh,
Now I see the difference.
They look like dowdy washers.
I'll have to wait for those but it looks like a better seal.
I'll put it on my list.
