Last Post: fafcpa
0 Indicators not flashing
Last Post: Gravitas
0 1982 rubber oil hoses
Last Post: Gravitas
0 Gear indicator missing
Last Post: Shahyaan
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
0 75 XLH Bendix Carb Spitting Gas - Video
Last Post: jibber
Johnc (75), x750rider (68), bart53 (68), bad rad (67), halfdrive (56), jag1 (49), Zuhaib (37)
  #851
Old 10th November 2019
Hippysmack's Avatar
well, could start by selling the hf vom.
I knew that was coming.
Originally Posted by Tomcatt View Post
Pull the stator out and physically check it.
I'll try to get started on it this afternoon.
I'll take some pics for the pedia also since I've got some time.
I had a hint of melting plastic last time I fired up so I'm bracing to just replace it.
I may get lucky, but that's usually not my pattern.
Old 13th November 2019
rewind it for less money. hd uses a 15awg magnet wire.
https://www.youtube.com/watch?v=3Lwr3USwM_I
Hippysmack's Avatar
Now you gone and done it.
I've been breaking it down slowly and posting pics in the pedia with the formatting and retaking pics and etc.
But I'll have it off tomorrow. Got the sprocket and clutch basket off.
I skimmed over your video but I may look into that.
I've never restrung one before. Sounds like a challenge.
Old 14th November 2019
go 3ph
https://www.youtube.com/watch?v=fYm6gPJxeR4
Old 15th November 2019
Hippysmack's Avatar
I've created another thread for the stator repair.
http://xlforum.net/forums/showthread.php?t=2075150
But I gotta feeling this is the problem.
sml1226 sml1226 is offline
Sportster/Buell Model: XL1275R
Looks like insulation... I'm guessing the coil is shorted pretty badly with that much of it there.
That re-wind is looking like a pretty solid idea at this point.
as far as the black color, that is typical and is not an indicator of trouble.
that blob of shinola is what hd seals the connection. this is where mine went bad. that goop broke down, oil got to the connections and over time, eddy currents caused the wire to break down to high resistance which finally burn the wire.
this was a tricky find since every time i checked, the stator was good, but remember, a vom is a go/no go test.
all it takes is a few good strands to pass.
for a definitive answer, you can meg it to see if there is leakage to ground through the windings but "be careful" since a megger in the wrong hands can destroy the unit by piercing the varnish with over voltage.
Hippysmack's Avatar
I don't think I can do an insulation test at this point.
If you look at the pics in the thread for the stator removal, I buggered up the insulation on the back side getting it off the engine.
It was stone cold stuck so I used a small crowbar to rock it back and forth to loosen it.
I knew it was bad anyway and there was no way to budge it.
edit:
Yeah, the goop being there is normal.
I noticed the wire pigtail getting more stiff near where it enters the goop.
There is no signs of a problem on the pigtail other than insulation pulled down at the regulator connector.
harley506d's Avatar
Sportster/Buell Model: 1200c
Wish i had taken a pic of mine while i was doing the clutch mod, my windings were green and very neatly wound and all tight. Some of yours look loose.
Best of luck if you are having a go rewinding! Braver than i !
Old 16th November 2019
Hippysmack's Avatar
None of them are loose when pushing against them but I see what you mean as not tightly wound.
I don't imagine they could get that far out of wind by themselves.
From aftermarkets I've looked at, this one looks poorly wound.
My ex boss always told me there is a fine line between bravery and stupidity.
It all depends on the success or failure of your endeavor.
Success makes you a hero while failure just makes you a dumbass....
So we may see if the sword points up or down as I sit and rest when I'm done.
