0 Q cams in 73 xlh ??
Last Post: 73HEAD
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
Old 15th July 2021
Shahyaan Shahyaan is offline
Sportster/Buell Model: 883 Iron
Shahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the roughShahyaan is a jewel in the rough
Default HD 1200 conversion ring gap
Hi
I purchased the HD 883 to 1200 kit but am having trouble with the ring end gap. The top rings need to be ground down so I’m not worried about those. The second ring however is way too out of spec on the larger side. I’m sitting at 0.023” the manual suggest max 0.020”
Would this still be acceptable?
Old 15th July 2021
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Where did you purchase the kit? Have you contacted them? A ring gap beyond spec to begin with won't get smaller. Perhaps the vendor can provide another ring set?
John
Old 15th July 2021
John
Was Harley themselves here in the UK. Spoke to them and was told they don’t really measure the end gaps they just install the kits as is.
This just sounds crazy since the top ring was butting up with no gap in both cylinders.
