0 why you can't be seen
0 need help with 68 XLH
Last Post: mrmom9r
0 Oil pressure switch
Last Post: Edster
Last Post: Fivecats
0 What oil temp do you run
0 HSR idle mixture screw
0 Gear and brake linkage
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
View Poll Results: How many miles on your rubbermount?
less than 5K 194 17.15%
5-10K 279 24.67%
10-20K 339 29.97%
20-30K 167 14.77%
30-40K 78 6.90%
40-50K 25 2.21%
more than 50K 49 4.33%
Voters: 1131. You may not vote on this poll
  #491
Old 1st December 2020
harley506d's Avatar
Sportster/Buell Model: 1200c
Originally Posted by pcontiman View Post
My tranny broke (at least it sounds like a hammer swinging around in there) and the shop says too many bearings are wallowed out to make it worth rebuilding the engine. Anyone out there got at 2004-2006 1200 motor for sale ? what thread should i look in ?
thanks.
Always seem to be plenty of engines for sale on Ebay, but usually 883's. But you could just swop your top end over
Just remembered, you would need to change primary gearing over also. (i think)!
Highly-Dangerous's Avatar
1. Yes... you can get a 1275 Hammer kit.
2. Why changing the primary gearing???? no need for it unless your riding stile requires that.
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 23rd December 2020
Yeah, you'd have a real stump-puller!!!
Old 8th April 2021
BKB's Avatar
BKB BKB is online now
Well, in November, at 111,000 miles, the crank bearings failed, and the crank assembly was replaced, along with the rings & lifters. $4,000. Yesterday, 1150 miles later, she puked oil on the back tire, started clattering & quit in the space of about half a mile. No oil light warning, just a little rear tire spin on leaving a stop, then the noise, then shut down. Haven't heard from the dealer yet, as to what the problem is. I was about 5 miles from them when it quit & they came out to get me with their trailer. I hope it was a parts failure on something they did. If not, this may be the end for this bike. After 11 years & all those miles, I'm gonna miss her. Can't afford a new bike right now, & since H-D no longer sells a bike that I want, I'll be getting a used one if I can find one that's not too $$$. Maybe I'll find that Roadster I've kinda wanted.
Old 9th April 2021
BKB's Avatar
Dealer called today. The drain hose from the oil tank had dry rotted & split. Dumped the oil on the rear tire & blew the new lifters out. Not their fault, technically, but I think they felt bad for not catching that hose. They had the bike for 7 weeks & coulda, shoulda checked everything maybe a bit better than they did. Especially on a 11 year old bike. I had changed the oil back in October, but didn't notice that hose being iffy, then. But, they are comping the labor & splitting the cost of the parts with me, so it's not gonna cost an arm & a leg. I'm happy. They really didn't have to do that for me. They pretty much got me as a loyal customer from now on.
Old 9th April 2021
sportsterpaul sportsterpaul is online now
Damnnnn Brian, that really sucks. Curious though as I had my drain hose on the black bike wore a hole rubbing/vibrating against the other hoses near the top rear of the tranny. Also, my three Sportys are all much older than yours with similar miles but not a single “dry rotted” line among them, hmmm?
Good on them to pitch in on the repair. I guess we won’t t be running to Crustys anytime soon.
I.B.A.#26543,
Old 9th April 2021
BKB's Avatar
Yeah, it sucks. Gonna have to ride Laura's bike for a bit, I guess. As far as "dry rotting" goes, it may be just as on yours... abrasion. Like I said above, I didn't notice any deterioration of that hose last oil change. Won't know till I go see for myself. Probly ride down there today & talk with them. Something else I'm going to have them check is the oil pressure sender. Did not see the oil light come on. Might have saved the damage if that had lit up. It came on at key-on & went out when the engine fired.
Old 23rd May 2021
jazzman jazzman is offline
Sportster/Buell Model: 883
Other Motorcycle Model: 101 Scout,68guzzi,250duc
jazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud ofjazzman has much to be proud of
Originally Posted by boomerguy View Post
Since I bought my 2005 XL883 standard, I haven't HAD to do anything other than scheduled maintenance and tires. I chose to vent the crankcase fumes to the atmosphere, replace the stock throw out bearing with the upgrade FAG bearing that was specifically designed for the purpose and replace the "grenade" (spring) plate with three stock plates that should have been in the clutch pack in the first place.
Performance has been flawless. It has never needed the carb adjusted and it has never burned or leaked any oil. I use Amsoil fluids and NAPA Gold oil filter.
The only item that broke was the base of my stock seat which cracked and is a common problem. I replaced it with a far superior Mustang seat which will never crack. All other mods or changes have been cosmetic or accessories. Excellent bike.
This sound exactly like me. I bought mine two years ago with 18000km on it. it now has 43000km on it. it came with 4 sets of handlebars, forward and mid mounts , two seats, back rest and rack and trickle charger. I've put the mids back on and the stock bars. I do a lot of long country out back miles, so I carry a spare belt which I can change on the side of the road if l ever have to. After always owning classic bikes, l love my new old bike. Parts are easy to get and cheap. It's my favourite bike I've owned and I've owned some beauties. Gonna sell my 68 Guzzi and buy a late rigid mount.
Into Bikes!
Old 23rd May 2021
I rolled 107,000 miles on the way down here, and saw 108,000 in Daytona. If I make it home next week 109,000.
Old 24th May 2021
vferdman's Avatar
vferdman vferdman is offline
vferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the rough
I am closing in on 60K miles on my 2004 883XL. Owned it since new. Love it. It's still an 883. Runs like new. Been a very good machine for me.
Vladimir
'04 tax-paid XL883
Pioneer Valley, MA
